how to remedy the continually loosening steering nut? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New Bonneville
Old 05-07-2005, 12:52 AM   #1 (permalink)
im gettin kinda cheesed at this. it loosens up and the front end starts clunking after about 300 miles. ***?
"fast on the gas, late on the brake"
David Allen - RAT coordinator DCI RAT Pack
3144271204
davidallen@donelsoncycles.com
daveallen is offline   Reply With Quote
Old 05-07-2005, 01:43 AM   #2 (permalink)
I just had warranty work done to replace the whole steering column. Mechanic told me they did replace a lot of them and Triumph revised the unit and hopefully the steering head bearings won't come loose again.
Henry8075 is offline   Reply With Quote
Old 05-07-2005, 04:51 AM   #3 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
And as a temporary fix you should tighten it way too tight (bars don't move) and gradually loosen it until you have satisfactory handlebar movement again.
Don't remember the correct torques for the operation though, but this was on the tips section of a maintenance manual I once gave a quick glance at. The bearing is supposed to keep from loosening up so easily when it has been tightened this way instead of tightening it straight to spec. Something about seating the bearings first and whatnot.
Disclaimer: and as deliberately overtightening a bearing sounds a bit strange to me, try this at your own risk.
Martin_R is online now   Reply With Quote
Steering Stem Nut HELP Tiger Dale Classic, Vintage & Veteran 5 12-26-2007 05:45 AM
remedy for armor all McQueen Classic, Vintage & Veteran 4 11-08-2007 01:12 PM
Steering stem mounts/nut size Treb Sprint Forum 1 04-03-2007 09:26 PM
Final Remedy for brake fix ??? HiVel Speed Triple Forum 0 08-04-2006 06:18 PM
Loosening the Chain zighawk Twins Talk 16 10-07-2005 06:50 AM
