AdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Old 04-28-2005   #1 (permalink)
TM
I got my Speed Triple -05 yesterday and I have noticed that the instrumentation-display restarts (self-test) from time to time. It has happened both while riding and when standing still (with engine running, if I remember correctly). Has anyone else experienced this?
TM is offline   Reply With Quote
Old 04-29-2005   #2 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Seems like there is something wrong (a bad connection somewhere?) with your bike. I have not seen this bug on my '05 Triple.
The only time the display seems to do the restart is after I set the gear change lights or turn on the bike.
Martin_R is online now   Reply With Quote
Old 04-29-2005   #3 (permalink)
Martin_R's Avatar
Old 04-29-2005   #4 (permalink)
Yeah, there's definitively something wrong with your display
Ephtriple is offline   Reply With Quote
Old 04-29-2005   #5 (permalink)
Old 04-29-2005   #6 (permalink)
The back of your instrument cluster comes off by pulling it back. It's held on by plastic mushrooms heads through rubber grommets. No tools necessary. (It's made to come off easily to attach the Triumph flyscreen)
Take it off and check the electrical connector block to the instruments. It should seat and connect with a click. My guess is that this connector is not fully seated and causing intermittant disconnections.
Good luck with it. Let me know how you do.
Sir_Loin is offline   Reply With Quote
Old 04-29-2005   #7 (permalink)
Old 04-29-2005   #8 (permalink)
TM
Thanks for the tip/info Sir_Loin, I'll check it out & return with the results when/if I notice any difference.
Old 04-29-2005   #9 (permalink)
TM
Old 05-17-2005   #10 (permalink)
TM
I checked the connector block, but it didn't seem to do the trick. I have also experienced a total display-freeze when I was driving. The speedometer stuck at 45km/h and 0 rpm regardless of actual speed/rpm, it even displayed this info a long time after I had stopped the engine and removed the key. I then restarted the bike and drove for another 5-10 mins, and the display started working again after a high rpm acceleration. Strange... :???:
Display Issue Agentorange Speed Triple Forum 3 09-02-2006 08:20 PM
Engine stalls out when warm & won't restart mjac62 T3 Sport / Touring Forum 7 08-28-2006 07:20 PM
Heads Up Display TripleThreat Speed Triple Forum 1 01-22-2006 02:08 PM
heads up display vampyrexxx The Rocket Science Forum 5 10-24-2005 11:30 AM
runs fine untill shutdown/restart no idle and rough Sprint Forum 1 06-02-2005 07:05 PM
