Ok, at my first service (this morning) I spoke to the mechanic and told him about my trouble with the display. He checked it, but couldn't find out what was wrong (no error codes, loose cables etc). So he ordered a new complete display to replace mine ( should arrive within a week or so), after that I'll see if the problems a related to the display only.
Thanks for the update and please keep us posted as your problems seem to be almost identical to mine. My display has started to do the resets a lot more recently.
Someone on another thread suggested that a similar problem on the earlier S3s would have been caused by low battery. I will hook the battery on an Optimate overnight and see if that does anything.
Update: I decided to s***** the Optimate idea after taking a multimeter to the bike. The battery seems fine. 12.75V with bike off, 12.00V with lights on and ~14.40V while running. So it definitely is OK and charging while the bike is running.
Also checked the connector block behind the display. Seemed fine and well greased. Took it out and bent the pins just a bit to make sure they connect well, but I doubt this is the source of the problem either.
I wonder where the actual engine sensor end of the lead is?
[ This message was edited by: Martin_R on 2005-05-24 09:35 ]
