Originally Posted by Risky07
I just bought the battery (Sears Diehard) just a few months ago. :...
Well at least should be covered by warranty
But given that your battery is fairly new ....
Are you sure the trickle charger was actually working?
Has it been connected
all the time the bike was idle, or did you just connect it recently?
If the battery was already discharged when the trickle charger was connected that would not recharge it - trickle chargers won't recharge a discharged battery - only keep it peaked.
If you have a regular charger, try re-charging it to see if it will recover to 'normal' capability.
