2008 Speedy spark plugs? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearOntario Tourism
Old 12-21-2008, 09:47 PM   #1 (permalink)
The manual for my 08 says:
NGK CR9EK with a gap setting of .7 mm.
Is this acurate?
" In a time of deceit, telling the truth is a revolutionary act." -George Orwell
skygodmatt is offline   Reply With Quote
Old 12-23-2008, 01:39 AM   #2 (permalink)
Favourite Bike: 05 Speed Triple
Ferris's Avatar
If that's what it say's. Do you have reason to question that?
What I'd like ti know is why the clutch lever hasn't been upgraded to match the new brake lever?
Ferris is offline   Reply With Quote
Old 12-23-2008, 05:52 AM   #3 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Sounds correct. If I remember right, that is the default NGK gap. Should not be much need to adjust on new plugs.
Also don't be tempted by the fancier single electrode racing plugs. Speedy runs and especially idles best with the dual electrode stock fitments.
Martin_R is offline   Reply With Quote
Old 12-23-2008, 05:55 AM   #4 (permalink)
Martin_R's Avatar
Upgraded how? The brake lever changed because brake master cylinder is now radial (so in effect the pushing direction rotated 90 degrees). Clutch is still direct cable operated, so no need for overcomplicated lever like on brake side.
Old 12-23-2008, 06:43 AM   #5 (permalink)
Favourite Bike: 07 Speedy 1050
Other Motorcycle: UNO TL1000S
Is this acurate?
If I remember right, with Technical News 103 (Sept. 2008), Triumph switched from CR9EK to CR8EK for all 1050's. You might check with your local dealer to verify this info.
JoE.
UNO30 is offline   Reply With Quote
Old 12-23-2008, 03:54 PM   #6 (permalink)
Ferris's Avatar
Yeah I fully understand the new brake lever, but the old clutch lever is a completely different shape and just doesn't look right. I just see it as corner cutting by not tooling another clutch lever!
Old 12-26-2008, 12:06 AM   #7 (permalink)
Switching to an 8 series would mean they are using a slightly hotter plug. Why?
http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
Old 12-26-2008, 09:34 AM   #8 (permalink)
How accurate do you need to be? Okay how about 0.7001 mm.
Chewie is offline   Reply With Quote
Old 12-28-2008, 10:33 PM   #9 (permalink)
Favourite Bike: 08 Speed Triple
wabill's Avatar
Other Motorcycle: 2010 Bonneville
Extra Motorcycle: 2010 FJR 1300
What is meant by "intermittent gap"
DON'T WORRY, BE HAPPY!
wabill is offline   Reply With Quote
Old 12-29-2008, 02:39 AM   #10 (permalink)
I have no idea what an "intermittent gap" is.
My owners manual for my 2008 speedy says gap to be .7mm. It is the same manual for the 955i and the Speedy but there are 2 columns listed for the specs. Perhaps an older manual? Should the gap be different?
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 15 10-27-2009 04:25 PM
spark plugs zoombass Hinckley Classic Triples 2 07-11-2008 06:22 PM
Where to get spark plugs faffyface Twins Talk 6 12-05-2005 01:38 AM
Spark plugs CrazyHorse Twins Talk 2 11-28-2005 09:14 AM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
