Clutch saftey bypass at startup? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-21-2008, 02:54 AM   #1 (permalink)
Do you guys know a way to start my 08 Speedy without having to pull the clutch every time?
I was thinking there is a bypass that someone did but I also don't want it to affect my ECU.
" In a time of deceit, telling the truth is a revolutionary act." -George Orwell
skygodmatt is offline   Reply With Quote
Old 12-21-2008, 04:42 AM   #2 (permalink)
Liftetime Premium
Favourite Bike: Grey 2010 K1300R - currnt
ruscook's Avatar
Other Motorcycle: Blue08 Tiger1050 - trade
Extra Motorcycle: White07 SpdTple - crashed
It would be easy to measure the switch operation that is on the lever assembly near the clutch and short it out. But why? It is a safety feature and a minor inconvenience. One that stops you starting the bike in gear and risking a drop.
Russ
ruscook is offline   Reply With Quote
Old 12-21-2008, 05:17 AM   #3 (permalink)
blacktiger's Avatar
Question
Originally Posted by ruscook View Post
It would be easy to measure the switch operation that is on the lever assembly near the clutch and short it out. But why? It is a safety feature and a minor inconvenience. One the stops you starting the bike in gear and risking a drop.
Russ
I agree with Russ here. I don't suppose your next question will be; "how do I bypass the kick stand safety switch?"
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
Old 12-22-2008, 06:43 AM   #4 (permalink)
Favourite Bike: '06 speed triple
Other Motorcycle: '07 WR 450
I had to do that when i replaced a clutch lever and forgot the bushing at the pivot. There is a wire that goes into the lever housing, use a small screwdriver to disengage the tab thingy and pull the wire.
throttlejockey154 is offline   Reply With Quote
startup question sandslinger17 Speed Triple Forum 5 07-11-2008 03:06 PM
Backfire on startup itcha Twins Technical Talk 4 10-18-2007 10:50 AM
New Saftey Recall Service Bulletin # 386 famonterojr Maintenance & Workshop Talk 1 09-27-2007 05:14 PM
Engine Rattle On Startup Stampy Speed Triple Forum 0 07-17-2007 08:45 PM
Fan on at startup and always coldnight Sprint Forum 14 05-06-2004 09:05 AM
