Question for '08 or '09 Owners - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports
Old 12-20-2008, 07:24 PM   #1 (permalink)
Can anyone measure the free length of the fork tubes when it's sitting on the side stand for me ? from the seal to where it goes into the axle carrier.... just the chrome part. Please.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 12-20-2008, 08:26 PM   #2 (permalink)
Favourite Bike: 1087 Triumph
Bonnie1000th's Avatar
Other Motorcycle: 1250 GSF
What you are trying to accomplish now?
Just ride the damn bike!
Bonnie1000th is offline   Reply With Quote
Old 12-20-2008, 11:45 PM   #3 (permalink)
Favourite Bike: 2008 Speed Triple 1050
Darkhorse's Avatar
this number will be different for every bike with different preload settings, and compression settings due to stiction.
Darkhorse is offline   Reply With Quote
Old 12-21-2008, 06:03 AM   #4 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
What Darkhorse said. As pretty much everyone has adjusted their static sag with the individual rider weight on board, everyone's riderless suspension sag will be different.
CYNCRZR, what are you trying to figure out?
Martin_R is online now   Reply With Quote
Old 12-21-2008, 12:01 PM   #5 (permalink)
Dispelling the doubt...
Oh you're a fine one to talk... But no, I'm not trying to swap the forks for Ohlins or anything... well not yet.
Just trying to re-assure myself that I haven't all of a sudden lost some ground clearance or fork travel.
Long story boring... yesterday I scrapped both sides of the Belly Pan while riding. Earlier in the day, a buddy made mention that there isn't much "Travel" to the fork... as in not a lot of fork tube exposed on the Speedy compared to the CBR600 parked next to me.
I know I ride the bike hard, I've 13k miles since I got it in may, and with the new Bridgetstone BT016's, I'm really comfortable pushing the bike through corners.
So I was just lookin for a Sanity Check, Mine measured 4.25 inches exposed. If someone else has 6", I'm gonna be concerned!
BTW, I used to be a die-hard Pirelli guy, but the BT016's are by far the best tire I've ever run. Looks like I'll get 3k outta the rear, 4 - 4,5k outta a front. They really stick. I only got 3k outta the Pirelli Diablo Rosso's and these work way better.
Cheers y'all
Cheers y'all, Cyn-
Members Album
Old 12-21-2008, 03:26 PM   #6 (permalink)
Favourite Bike: Speed Triple
Other Motorcycle: Ducati Street Fighter
When I expose my "tube" it's more than 6". Otherwise I doubt my wife would have married me.
29138 is offline   Reply With Quote
Old 12-21-2008, 06:39 PM   #7 (permalink)
Favourite Bike: 07 Sprint ST
LarryS's Avatar
Other Motorcycle: 08 Thruxton custom
At the risk of insulting you......
Was your butt planted square in the seat or did you hang off and weight the inside peg when you scraped? I'll assume the scraping was done in a turn. If not, time for Weight Watchers!
Where I'm going with this is that if you shift your body center line to the inside and weight the inside peg, you will need less lean angle.
I'm 210lbs (Yes I do need Weight Watchers) and have had it down to the point of almost low side and never scraped.
"All that is required for evil to prevail is for good men to do nothing." -- Edmund Burke
LarryS is offline   Reply With Quote
Old 12-22-2008, 03:05 AM   #8 (permalink)
Darkhorse's Avatar
+1000
Plus, if you try to ride smoother, you'll load your suspension less. Try rolling on to the brake at the same time as rolling off the throttle. It'll help with the ground clearance issues somewhat. Having extra left over travel in your suspension also gives you a better safety margin for emergencies, etc.
In any case, I have heard of people complaining about draggin the belly pan before. Its prob just a poor design.
Old 12-22-2008, 06:23 AM   #9 (permalink)
Martin_R's Avatar
That is normal for the 1050 OEM bellypan.
It touches down relatively easy.
Old 12-22-2008, 10:11 PM   #10 (permalink)
S3Junkie - So what you're saying is ... You're a Dick ?
Martin - Thanks that's re-assuring. Since the thing looks like it's been sand blasted already, I aint too upset over some Battle Wounds
Cheers y'all, Cyn-
Members Album
05-07 spd III owners (handlbar question) Chris Doe Speed Triple Forum 10 06-26-2008 04:55 PM
Question for Corbin owners bete Sprint Forum 23 08-17-2007 08:40 PM
Question for the Zard owners huff955 Speed Triple Forum 52 09-15-2006 02:01 AM
Question for '05 Sprint owners? paulvt1 Sprint Forum 1 04-09-2005 09:43 PM
Question for Corbin owners: shawboy Sprint Forum 9 07-31-2004 10:50 PM
