Big bike - small bike - cornering ! - Triumph Forum: Triumph Rat Motorcycle Forums
Riding and Survival Skills Tips for improving your riding skills and your survival on the road.
Old 08-13-2008, 02:04 AM   #1 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Just seen this on a government motorcycle safety site:
Cornering at safe speeds is easier to live with if you're riding a powerful bike, because acceleration helps regain cruising speed quickly once you're through. Low-powered bikes create the temptation to carry more corner speed than is necessary.
I've never really given this much thought, I've always considered I can corner faster on my bigger cc capacity bike although lightweight low-powered bikes are no slouch going around corners either.
Overall I tend to ride the different bikes I've owned to the best of mine and their ability, I suppose I may feel safer on the bigger bikes.
I can only suppose to the above is that a low-powered bike tends to be ridden 'flat-out' and as such is at the extremes of its handling.
Anyone any views on the above 'safer riding' statement ?
Ride on !
Tbirdnz is online now   Reply With Quote
Old 08-14-2008, 11:30 AM   #2 (permalink)
By this logic a cruiser with low ground clearance would be safer to ride through a corner than a sportbike since you are forced to slow down due to the design of the bike.
That dog won't hunt.
skiTTles is offline   Reply With Quote
Old 08-14-2008, 12:08 PM   #3 (permalink)
Lesser spotted moderator
Favourite Bike: 2006 Bonneville Black
saphena's Avatar
Other Motorcycle: Huoniao HN125-8
It sounds like something conjured up in a brainstorming session in some ministry of non-bikers.
Big bike, small bike, whatever - I ride according to the terrain and conditions. I can't imagine me deliberately riding too fast merely to get somewhere a few seconds earlier.
Bob - Ringer, Iron Butt, not dead yet
Switch to reserve ~120 miles, fuel panic ~150
"Just because you're offended doesn't make you right" Ricky Gervais
saphena is offline   Reply With Quote
Old 02-11-2009, 03:19 AM   #4 (permalink)
Newbie
I think your right.... big bike or such small bikes are the same for me, i ride for just enough speed for such places... it depends on the high way situations....
_________________
buell blast parts
bengomez is offline   Reply With Quote
Old 02-11-2009, 11:29 PM   #5 (permalink)
Favourite Bike: 2000 Sprint ST
Other Motorcycle: 1999 Sportster Sport
[B]Cornering at safe speeds is easier to live with if you're riding a powerful bike, because acceleration helps regain cruising speed quickly once you're through. Low-powered bikes create the temptation to carry more corner speed than is necessary.
Ride on !
I think the engine size is a red herring...
Light weight bikes tend to handle pretty good, and good handling bike coaxes you into taking corners quickly. A bad handling or heavy bike may cause you to slow down in the corners (because it will scare the crap out of you). I once had a '64 Yamaha YD3, and that was the effect it had on me.
Basic research is what you are doing when you don't know what you are doing...
Razzoo is offline   Reply With Quote
Old 02-14-2009, 08:37 AM   #6 (permalink)
Sounds like something someone made up as a 1-up to sport bikes.
Lame.
When I go into a corner on the highway, I'm thinking about the safest speed to take the corner safely, not the greatest speed I can manage to pull out of the corner.
ModernMuseum is offline   Reply With Quote
Old 02-14-2009, 12:51 PM   #7 (permalink)
Favourite Bike: '03 Daytona 955i
HiDesert's Avatar
It all depends on how you define 'necessary.'
saphena is right. This smells like the product of a hand-wringing session to me.
I won't stop riding because you tell me about someone who died in an accident, just as I won't stop eating because someone died of e.coli.
HiDesert's ride photos
HiDesert is offline   Reply With Quote
Old 02-23-2009, 01:06 AM   #8 (permalink)
Favourite Bike: 06 Scrambler 900
Other Motorcycle: Rocket 3 Classic "08"
"Powerful Bike" VS "Low powered Bike"
A powerful bike might be complete with better tires, shocks, brakes and a better CG. This will enhance the corning ability for the rider. I read somewhere that most riders go into corners too fast and then not being set up properly for the exit acceleration speed. Because during the turn they see that they are to fast and have to slow down when in fact they should be accelerating their way out of the turn if the entry speed was right.
Maybe the higher powered bike with better equipment helps eliminate many accidents that might of happened on the lower powered bike with lesser equipment. But whatever happens its the rider who twist the throttle. The bike does what it is told.
odie
odie is offline   Reply With Quote
Old 02-24-2009, 11:22 PM   #9 (permalink)
HiDesert's Avatar
That's easy to diagnose; did you power through your last turn, or did you do the "won't this twist any further away from me?" If (1), you don't have the 'going into corners too fast' problem. If (2), one wonders if you produce ink when startled.
Seriously though, if most riders went into turns too fast, I think the accident rates would be even higher than they are. But that's just an off the cuff response.
Old 03-05-2009, 01:16 PM   #10 (permalink)
I think most self induced crashes in a turn is when the rider is exiting a corner.
TheMojoRider is offline   Reply With Quote
Best Small Bike decobike Biker Hang-Out 10 01-23-2008 10:07 PM
Super Bike and Fast Bike mag's Jon.sb Street Triple Forum 0 10-03-2007 03:29 PM
dont you love other dedicated bike forums talikng about your bike bakwheeltango Sprint Forum 11 07-31-2007 09:03 AM
Chatterbox GMRS X1 (bike to bike) review BonnieLass Gear & Gadgets 0 06-20-2007 03:28 PM
Bought a used bike. (06) Missing a small part. jayb Speed Triple Forum 14 07-04-2006 02:29 AM
