Before I add my $0.02 worth, I'll preface by saying that I've been doing motorcycle joy rides and tours for 15 years on a 1982 Harley Shovelhead. I've taken passengers for rides from 10 minutes to whole weekends and from 5 year olds to 95 year olds. I've carried cameramen sitting backwards and even a woman facing backwards sitting on the tank...
- The first thing I'll say is "Relax". This is the most important thing. You never want your potential passenger to be worried that you're worried.
- The next thing is to be positive that they're going to have a great time and ask them whether they've ridden, whether they've ridden pillion or whether they've never been on a bike before.
- The pre-ride doesn't need to be war and peace. It needs to be concise, to the point and above all, designed to give them the impression that you know what you're doing. If you spend 20 minutes telling them all the pitfalls, they'll more than likely get scared off.
This is what I would do.
1) Point out the footpegs, backrest and where to hold on
2) Tell them how to hang on to me, or if they prefer to hang on to a rail or rack
3) I get on the bike and stand it up off the stand and steady it with bars and feet spread wide.
4) Tell them to put their left foot on the left peg, use your shoulders and the back rest if necessary and get on as if they're getting on a horse. i.e. Stand up on the left peg, then throw their right leg over to the right peg and sit gently. Using your shoulders as a steady helps you balance the bike and them at the same time.
5) Once they're on, you can revise the hanging on bit
6) Demonstrate how the bike will lean around corners and not to worry, it's supposed to do that and that's part of the fun. Tell them that they should not lean, but just go with it.
7) Cover the braking - tell them if they feel themselves sliding forward to push down on their feet and even put their hands on their knees and push down. That's how my wife rides, hands on her knees and yes, she sleeps on the bike often on longer trips.
8) Mention that they need to leave their feet on the pegs and sit as still as possible when you're coming to a stop. IF they need to change positions, get them to tell you before they do it.
8) Now we take off, slowly, smoothly and in as straight a line as possible. Tell them to relax and enjoy the ride!
9) Once you get going you cen demonstrate a weaving motion slowly to get them used to turning and tell them that if they lean the wrong way it makes it harder for you to turn. You can also do a test stop just to demonstrate the mechanics of it.
10) Also as you take off, it's really important for you to get your feet on the pegs too. Having them sliding along the ground is no good for your centre of gravity and makes it harder to get your balance quickly. Same with the waddle, there is no need unless you're really badly set up.
All in all, you need to make it as relaxed and fun, and above all, be positive about it yourself. If you're a good rider on your own, adding a passenger shouldn't be a real issue at all.
Mick
