Back tires slipping/sliding/wobble in turns - Triumph Forum: Triumph Rat Motorcycle Forums
Riding and Survival Skills Tips for improving your riding skills and your survival on the road.
Old 04-22-2009, 11:17 AM   #1 (permalink)
Newbie
I bought new 2008 Bonnie T100 about month ago.
Entering a turn, the road signs have it posted to take it at 40, I'll smooth in at 45-50 not downshifting and slowly throttle out of the apex. That's when the tire will slip/slide around the apex and wobble a bit after right before I straighten up. At first I thought it was because the patch I just rode over had a little sand on it and shrugged it off, but it persisted later on the day. It left me feeling a little nervous. I checked the tire pressure when I got a station and it read 42 psi, just what the tires said.
A recent curious thought, I'm over 700 miles now and have yet to go in for the 600 break in maintenance - I do plan to get this done, this coming Saturday hopefully. Could it be that?
dewdlebug is offline   Reply With Quote
Old 04-22-2009, 11:54 AM   #2 (permalink)
Something doesn’t sound right at all. Check for something being loose back there (wheel, suspension, swingarm…?), or have the dealer check it out when you take it in for the work (maybe they were hungover when they unboxed it and missed something ).
skiTTles is offline   Reply With Quote
Old 04-22-2009, 05:47 PM   #3 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
I agree with SkiTTles there, something is not right, I'd check it out immediately, I'd raise the rear wheel off the ground and check out if there is any side-ways play in the rear wheel or the suspension. Spin your wheel and note if the tyre is on correctly. I'd also take it into the dealer asap even if you don't find anything and have them check it out. The Bonnie is one of the safest and easiest bikes to ride, what you are experiencing is not the norm.
Keep us posted on the problem.
Ride on !
Tbirdnz is offline   Reply With Quote
Old 05-29-2009, 09:22 PM   #4 (permalink)
bsakel's Avatar
Everyone is right, check the mechanicals first. But you also might be accelerating too hard coming out of the corner causing the rear wheel to start breaking loose. When you fully straighten you regain traction.
Just an idea, watch your exit speed and see if that helps.
bsakel is offline   Reply With Quote
Old 05-31-2009, 10:07 AM   #5 (permalink)
Lee
Multi-Iron Butt Moderator
Favourite Bike: Triumph RIII Graphite
Lee's Avatar
Other Motorcycle: Honda Goldwing 2012 Red
Extra Motorcycle: Is it really ever extra..
If you have ruled out anything loose try checking the for any abnormalities unevenness. Possible defect of sorts like a displacement. Beings it is only on the turns when you straighten up I would not think it is the tire balance unless you just did not notice it as much.
Four Iron Butt Rides Todate....Will Be Working On Longer Ones In The Upcoming Year...Jersey Born and Raised........Texas run 1000 in 24 hours in April 2012
Lee is offline   Reply With Quote
What are the largest tires are you running (front & back)? skos Sprint Forum 10 10-27-2008 11:21 AM
sliding backrest ? dertbikdennis The Rocket Science Forum 6 04-29-2007 10:33 PM
Fan turns on.. Engine turns off? Natron037 Triumph SuperSports 6 04-25-2007 04:55 PM
Backin it in - ( a term for sliding the rear through turns) Hairball Speed Triple Forum 34 08-02-2006 03:45 PM
The back wheel is sliding?? Psychlopath Twins Talk 21 07-24-2006 06:12 PM
