Trident 900 ignition fault - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
RAT - United Kingdom Topics and Discussion for RAT Packs based in the U.K.
Old 10-01-2008, 11:47 AM   #1 (permalink)
Favourite Bike: My Trident
BikerBaz900's Avatar
Unhappy Trident 900 ignition fault
Hi all
I just finished fitting a new airbox and fitted the airbox without a problem however the bike will not now start - and misfires like a timing issue - so i thought had messed up the wiring of the HT ignition coils. Worse still after doing some fault finding discover that ALL 3 plugs are sparking at same time - and looks like every stroke - lit up light a christmas tree.... All i have done is disocnnect and reconnect the HT leads....
Any help welcome, Thanks Baz
My Haynes manual, whilst showing the wire colours does not indicate which wire goes to + & - on each coil which is not too helpful - anyone with a tank off that can confirm as below?
The way i have it wired is;
HTC1 to Cylinder 1 (Left side)
Brown/Yellow - I have on negative
Red - I have on positive
HTC2 to Cylinder 2
Yellow/Blue - I have on negative
HTC3 to Cylinder 3
Green - I have on negative
BikerBaz900 is offline   Reply With Quote
Ignition switch wire fault Bonnevillet140v Sprint Forum 3 06-25-2008 05:31 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
are later trident handlebars higher than the early trident bars trent RAT - United Kingdom 3 06-08-2006 05:18 PM
are later trident handlebars higher than the early trident bars? trent Maintenance & Workshop Talk 3 06-05-2006 01:22 PM
1998 Trident 900 noise like pre ignition only under load 3500-5000 rpm triple900 T3 Sport / Touring Forum 4 07-18-2005 08:50 PM
