I have a 2006 Thruxton, all I've ever used is the Mobile One that the factory recomends. But it's high dollar and not available everywhere. The manual REQUIRES fully or semi-synthetic, 10W-40 or15W-50 weight, meeting API grade SH OR HIGHER and JASO MA. The JASO MA means that there are no friction modifiers that will cause your clutch plates to slip. There should be plenty of brands that meet these specs., assuming that API specs. are used throughout the world. I found out that when the specs. are upgraded by a letter ( the S stands for spark ignition, so it's the second letter that is upgraded ), the higher spec. letter is just added after the original spec. designation, ( eg. 15W-50, SH/SJ JASO MA ).I hope this helps you find the right oil; I don't know what brands are available in the U.K. Myself, I'm going with Amsoil 20W-50 in my next oil change, it's a bit cheaper, more available, and the Amsoil company claims that you can double the change interval with a only a filter change at the normal 6000 mile interval or one year whichever comes first. This will work for me, as I only run just over 6000 miles a year in the first place.
