I have just removed the Fuel tank on my 2003 955 Daytona and on the fuel pressure regulator there is an outlet for a rubber tube, But there was nothing attached to it.On this model should there be a pipe attached to this outlet and if so where should it go to. Any help appreciated Cheers Simon
The two pipes on the other side of the tank reffered to by redmellons are :- for the tank overflow and a drain for the filler well.
Aren't those the 'fuel filler drain' and 'fuel tank vent' on the left side of the tank referred to in instruction 2 in the manual? Instruction 5 then says 'reconnect the hose leading to the fuel pressure regulator'.
Just to clarify. There used to be a pipe on the regulator. Hence the reference to it in the manual. At some point Mr Triumph decided it wasn't required and deleted it. I have an 04 daytona and it has never had the pipe. So sleep easy carr955 all is well !
