My Patience is Running out Rapidly!!!! - Triumph Forum: Triumph Rat Motorcycle Forums
RAT - United Kingdom Topics and Discussion for RAT Packs based in the U.K.
Old 07-18-2006, 05:28 PM   #1 (permalink)
lancashirelad's Avatar
Picked the TBS up tonight from the dealers, they've been again attempting to find the elusive intermittent misfire, this time they've disconnected the side stand switch to see if this cured it, opened it up on the motorway & it started again!!****
It does it above 5000 revs & the tacho needle flickers, then it settles down again, its still under warranty & upto now its had the carbs drained, the CDI unit renewed & now the side stand switch disconected.
I've thought for a while its either a dodgy coil or maybe the ignition pickup?
Anyone any other ideas???
My next move may be to take it up with Triumph
lancashirelad is offline   Reply With Quote
Old 07-18-2006, 06:21 PM   #2 (permalink)
Favourite Bike: 03 America
EnglishWombat's Avatar
Other Motorcycle: 06 America
Extra Motorcycle: 1945 Triumph 3HW
Have you had the coils changed?????
I know my bike is slighly different to yours, but the symptoms you're describing..... I have had a new brain thing, new wiring harness, plugs, caps, and one new coil. All under warranty. That solved it, for a good 6 months and then it started again.... So the other coil was changed and so far, touch wood, the problem has gone.
Get them to try it....
Oh and do you have an alarm fitted??? It may sound daft, but that was the start of all my woes...
Gina
http://bestsmileys.com/animals/7.gif
EnglishWombat is offline   Reply With Quote
Old 07-18-2006, 07:09 PM   #3 (permalink)
The coils have not been changed.........yet!!!!
There is an alarm fitted, but all along I've been inclined to think it was one of the coils for some reason...
Old 07-19-2006, 05:44 AM   #4 (permalink)
What alarm is it????? Is it the Triumph/Datatool alarm or some other make???
I ask because I've been in touch with Triumph about the problems I had with mine....
I had the alarm fitted because I was under 30 and it took £150 of my insurance quote. I was still paying over £400.... The alarm has paid itself for this year! Also I don't have a garage, and it's parked in a public car park at work. And it was fitted between failing my first test and passing my second.... :
Anyway I digress...
My receipt says genuine Triumph Alarm....but it wasn't. I'm now on alarm number 4 that is a genuine Triumph alarm....
With the geniune alarm, it should plug straight in. They put a plug in the harness so there should be no hacking into the cables. With the one I had fitted they had to cut into it. With modern bikes having a processor thing they'll be as prone to problems with static as a computer. And static can go through a system like a dose of salts.
So if your alarm is not Triumph/Datatool....
See what I mean???
Get the coils changed. I'm not a technical person, but your problems sound the same... though I don't have a tacho, so that bit I don't know about.
If that doesn't help, then get in touch with Triumph. At least you'll have done all the sensible stuff before ranting at them...
Gina
Old 07-19-2006, 12:16 PM   #5 (permalink)
Its the Triumph Datatool alarm, the fobs have Triumph on em anyway.
Going on a Rat run tonight, that will be the decider, if it plays up again, I'll get back onto dealer.
Thanx for your replies.......
Neil.
Old 07-20-2006, 04:29 AM   #6 (permalink)
Well.... How did it go???
Gina
Old 07-20-2006, 04:39 AM   #7 (permalink)
Lift your tank & have a look at your vacuum hose that runs from one of your carbs to the petcock. Make sure it has not got a kink in it. This has happened to me before. Your bike runs well untill higher revs when your carbs demand more fuel & just doesn't get it due to insuficient flow from the petcock. This is because the vacuum hose is not producing enough "suck!" to fully open the petcock valve.
Hairyetti is offline   Reply With Quote
Old 07-20-2006, 12:49 PM   #8 (permalink)
It misfired quite a bit, but I'm not going to start looking for problem myself as its under warranty, awaiting news from dealer..
running in DALERF Daytona Deliberations 9 10-07-2007 10:04 PM
Patience Granty Sprint Forum 8 05-26-2007 01:56 AM
Still not running right. kawtoy Classic, Vintage & Veteran 6 08-30-2006 11:06 AM
stops running after reaching running temp. ADVENTURERONE Hinckley Classic Triples 7 10-25-2004 09:11 PM
Running in RobUK Tiger Chat 4 07-09-2004 07:48 PM
