Any vehicle with a gross vehicle weight (GVW) or gross train weight (GTW) over 3500kgs or a motorcycle above 50cc must, comply with either:
1. The grooves of the tread pattern must have a depth of a least 1 mm throughout a continuous band measuring at least three-quarters of the breadth of the tread and round the entire outer circumference of the tyre, OR
2. If the grooves of the original tread pattern of the tyre do not extend beyond three-quarters of the breadth of the tread (i.e. common with motorcycle tyres) any groove of the original pattern must have a minimum depth of at least 1 mm.
I feel a need to wear an anorak
[ This message was edited by: Levenvale on 2006-07-22 14:47 ]
Time flies like an arrow fruit flies like a banana.
Groucho Marx
