RAT - Canada Topics and Discussions for Canadian RAT Packs
Old 05-24-2005   #1 (permalink)
tipere
Hi,
I just bought a '96 Adventurer with 31000km on it. It original no mod's. Since I have for a month, the tach is going erratic at about 3000rpm. Before I took it out last week I washed it with s-100 cleaner for motorcycle. To my surprise the tach goes from 2000 to 5000 rpm as it was receiving some surcharge. The high temperature light came on also wich it never did before the wash. By the way ,I touroughly rinsed bike for soap residue. So this weekend I disconnected the tach (three pin white plug) to the tach and this morning, going to work, there is still somme movement of the needle in the tach, from 0 to 2000rpm.
HELP !!!
Michel :???:
Old 05-24-2005   #2 (permalink)
Great classic :razz:
Check also your LV electrical connections on your ignition coils..
They are located under the fuel tank on the right side
Concerning the ligting of the high temp, check if your bike is overheating or not
1st check your coolant level, both in tank an radiator
2nd check if your cooling fan is working
3rd ( most probable) If your bike is not actually overheating, it comes from insufficient ground on the wire harness.
[ This message was edited by: legend21 on 2005-05-24 07:50 ]
legend21 is offline   Reply With Quote
Old 05-25-2005   #3 (permalink)
tipere
Merci pour les commentaires, mais rien n'y va. J'ai même disconnecté le tach. et l'aiguille saute encore mais de 0 Ã* 2000 rpm. Autre chose de bizarre, mon copain a une Legend 2000 dont le boîtier du phare avant est mis Ã* la masse tandis que le mien ne l'est pas. Y a-t-il eu un Service bulletin émis par Triump Ã* ce sujet, si oui comment se le procurer ?
Merci Ã* l'avance
Michel
Old 05-27-2005   #4 (permalink)
la mise Ã* la masse c'est pour attenuer l'allumage intempestif du témoin de température c'est pas indispensable
Y a eu le même pb sur les trophy...
Va poser ta question chez les cousins français de TÃ*D, fait gaffe on est une bande de fous furieux, mais faut pas s'arrêter sur les gamineries des grands enfants que nous sommes ...@+
L21Triumphadonf
Neutral light is erratic!!!! slowkitty Hinckley Classic Triples 2 10-11-2007 08:11 PM
erratic idling DrewDesign007 Twins Technical Talk 9 10-03-2007 08:06 AM
Erratic Idle gt1jimi T3 Sport / Touring Forum 2 05-19-2007 04:31 AM
Erratic Tachometer BigAl8295 Hinckley Classic Triples 5 04-29-2007 12:03 PM
REALLY Erratic Speedo TBSstunta Hinckley Classic Triples 8 09-19-2006 02:54 AM
