Originally Posted by Mr Luke
Hey mate
Who did you end up going with and were you happy?
I went with Ozzy in the end.
I wasn't 100% happy to be honest.
Ended up with the wrong map installed for the ECU. Some map off the internet. I took it to Triumph Springwood a couple of days ago and they installed the correct map and it runs a lot better.
There were a few things like in the list of work done, cleaning the chain was listed but it was clearly not cleaned.
I had a problem after the service with oil leaking and he said it was because the o-ring was stuffed. It wasn't, it was just done up too tight.
