When Will My Motorcycle Battery Die? - Triumph Forum: Triumph Rat Motorcycle Forums
News Room - Homepage Infobits and Newsworthy information about motorcycling, Triumph, TriumphRat.Net. All submissions are manually approved.
 1Likes
  • 1 Post By sonicboom
post #1 of 4 (permalink) Old 02-22-2017, 03:46 PM Thread Starter
It depends where the bike lives: Hot and cold climates are both harder on batteries than temperate climes, and bikes that get ridden regularly are easier on batteries than ones that sit for months – though a good battery tender with a float feature negates much of that. In fact, I was bragging about the Shorai lithium-iron battery in my bike not long ago, which must be seven years old now and has never seen a charger, when my friend Jim said big deal, the original equipment sealed AGM battery in his VFR lasted 9.5 years, and his 21-year old Ducati is only on its second battery. So, sealed batteries can last a long time especially if you’re OCD about maintenance.
According to several sources including BatteryStuff.com, though, your 12.3-volt reading means your battery may be on its way to Nirvana; a fully charged one should read 12.7 volts or above. Since you like to play with your voltmeter, there are instructions to “stress test” your battery at the same page, along with a lot of other battery tidbits that will let you know for certain if it’s time to replace.
Send your moto questions to AskMOAnything@motorcycle.com. If we don’t know the answer, we know who does, and if they don’t know we’ll make up something reasonable-sounding. What do you want for free?
Read more about When Will My Motorcycle Battery Die? at Motorcycle.com.
Motorcycle.com is offline
post #2 of 4 (permalink) Old 02-22-2017, 03:53 PM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
My first battery lasted like 9 years. The second one died after only 2 years, on the third one now. I have found those Yuasa about the best for longevity. You can go on e bay and find those Yuasa's for a good price with free shipping.
Don't bother with the Battery Plus Bulb stuff, there stuff not as good as the stock battery for this bike. Go Yuasa and they last.
Steve Ford likes this.
sonicboom is offline
post #3 of 4 (permalink) Old 04-20-2017, 08:08 PM
Main Motorcycle: TRIUMPH T120 Bonneville
Colt3374's Avatar
10 years out of my Yuasa in my 2007 Roadstar..gave up the ghost at the dealership while trading in for MY new 2017 T120
Colt3374 is offline
post #4 of 4 (permalink) Old 04-20-2017, 08:59 PM
Main Motorcycle: 2011 Speed Triple SE
I bought my bike used but have all the maintenance records and receipts since new. The PO only got a year out of the original battery. I'm guessing it was a Yuasa? Anyway, whatever Triumph put in there. He replaced it with a Yuasa. That one lasted 5 years and just tanked this spring. I've been diligent about keeping it on a tender, but it wouldn't hold a charge. When I took it out, I saw that it was also starting to ooze just a little bit of acid out of a seam in the plastic.
I replaced it with a high dollar Shorei lithium battery which is crazy light and will supposedly sit for a year without needing a battery tender etc. Time will tell.
T Dad is online now
Triumph T160 charging system confusion 2wheelride Classic, Vintage & Veteran 21 09-26-2016 11:44 PM
'71 TR6R ignition BMDitty Classic, Vintage & Veteran 26 05-07-2016 01:09 PM
Battery draining and gear engaged. Help welcome! Berlino Air Cooled Twins Technical Talk 29 04-21-2016 04:22 AM
TB Overcharging The Battery Zebraranger Hinckley Classic Triples 5 03-29-2016 04:52 AM
melted fusebox and flat battery blueblackhussar Daytona Deliberations 5 04-20-2015 06:59 PM
