Old 05-03-2002   #1 (permalink)
This one's probably a no-brainer to most but I've just found out about it and thought I'd pass it along. If you're using the plastic valve stem caps switch to the metal ones(they have a small o-ring inside). You won't have to pump in those 2 lbs. that find their way out past the plastic valve stem cap every other week or so.
j98sprint is offline   Reply With Quote
Air Leak in Valve Stem Fed Modifications & Workshop Talk 3 05-24-2007 09:03 PM
valve stem nut Programr Twins Technical Talk 4 12-24-2006 03:26 PM
Valve stem leaking t100bob Twins Technical Talk 4 10-08-2006 05:31 PM
valve stem replacement madmic Tiger Workshop 2 09-06-2006 06:59 AM
Right angle valve stem adapter martingilly Hinckley Classic Triples 4 08-27-2006 10:18 PM
