The shims are only available in thicknesses in multiples of 5, i.e. 260, 265, etc.
Since the tolerances are .10-.15 or .15 -.20 for my Legend, just find a new shim size that will fall within the recommended tolerance range. It might be good to remember that when checking gaps with a feeler guage, the gap will likely be somewhere between the size of the feeler that slides thru and the next size up that won't slide thru.
A site that was helpful to me was the following:
http://www.webbikeworld.com/t2/valves/
