BikeBandit
Old 05-24-2008   #1 (permalink)
Newbie
Favorite Bike: Triumph America
Other Motorcycle: Yamaha xvs650
EFI or Carby
Hi everyone I am a noob. I currently ride a Yamaha xvs 650 classic with no mods. I'm still on my p's and go to my blacks in october (I live in Australia). I am hoping to be the proud owner of a Triumph America 08 model after this point but here lies the problem. The EFI models are just comming out here and look very tempting BUT.... I have been told that if I was planning to change my pipes to anything but triumph aftermarket pipes I should still go carby and change the jets instead of EFI and re-map as the map would most likely be 'not perfect' and in the long run ruin my engine.
Any thoughts???
At the end of the day i want to change the countershaft sprocket to 18 or 19 teeth, change the pipes, change the air filter and change a few other things for style, comfort and cosmetics.
I sat on one today, I had to try so hard not to buy it on the spot.
mongle
mongle is offline   Reply With Quote
Old 05-24-2008   #2 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
mongle, Welcome to the forum.
I'd suggest the EFI as in the long run it should be better.
Brad
Old 05-24-2008   #3 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
EFI and a TuneBoy will give you far better precision carbs & jets. As far as ruining the engine goes, somebody's feeding you some hardcore disinformation. Throwing in the Triumph off-road tune with some random set of pipes & a K&N is probably about the same as dialing in your jets with a plug chop yourself. Not perfect, but close enough. Setting your air:fuel ratio & fuel map with a TuneBoy is closer to having a set of carbs custom built for your motor. There is a level of control available that is simply not there with analog parts. EFI has been around a long time; most of the bugs are gone.
Cheers,
-Kit
Old 05-24-2008   #4 (permalink)
Newbie
Thankyou all very much. I suspected EFI was better and more accomodating, but when you don't know much, a confident person can make one question oneself. Believe it or not this person was a dealer at a dealership so I suspect he just wants to get rid of the carbs to make way for the efi's!!!
Thanks again and i'll keep you posted on other stuff I find out.
Mongle
Carby warmers??? eternity Twins Technical Talk 9 09-12-2007 11:01 AM
Carby Upgrade Blackjack Twins Technical Talk 30 02-17-2007 01:34 PM
Carby black vacuum nipples Jam Twins Talk 13 05-19-2006 11:09 PM
Bugger 1 week wait on carby jets and stuff. Dave67 Club Cafe 6 06-24-2005 06:39 AM
