» Log in
User Name Not a member yet?
Register Now!
Old 1 Week Ago
Newbie
TT600 - which TPS wire for Power Commander
Which wire in the Throttle Position Sensor do I tap into for a Power Commander on a 2002 TT600. The instructions say yellow wire with blue tracer, but I don't have that colour wire. Please help.
Old 1 Week Ago
Shaun's Avatar
Newbie
Favorite Bike: 2003 TT600 caspian blue
Hi,
Just fitted one to my 2003 model. You need to tap into the green wire with the yellow tracer. The PC kit instructions are a bit out of date. If you look at the fitting instructions for the 2003 on S4 then it says green/yellow.
Also top tip.....found out the hard way.....make sure you connect the injector connections the right way as per the instructions, they will fit both ways, I got cylinder 3 wrong and have managed to illuminate the engine management light as it was missing not firing on number 3, it takes 40 start/heat up cycles to go out......or a visit to the dealer!
I have a Triumph carbon can on mine (2003 UK bike) and put the map from the web in with an aftermarket can by micron. The bike is better but there is a bit of a flat spot at 4000rpm. Everyone says a visit to the dyno is a must with the TT600, so I'm going to book mine in.
Hope this helps, let me know how you get on.
Regards,
Shaun
Old 1 Week Ago
Newbie
Thanks Shaun. Stupidly I didn't make a note of the colours of I wires so I'll have to have another look.
Which wire is the power Boriqua Twins Technical Talk 9 01-31-2008 07:38 AM
tt600- speed four power commander Treehugger Triumph SuperSports 6 09-26-2007 08:38 AM
Power Commander map for TT600 with yoshimura rs-3 wileytt Triumph SuperSports 0 07-03-2007 01:42 PM
Zumo owners - where did you wire in power? noobcorpse Sprint Forum 7 06-12-2007 10:55 AM
Will the TT600 Dynojet Power Commander Work On A 2003 Speed Four??? Triumph SuperSports 4 06-14-2004 02:03 PM
