Hi,
Just fitted one to my 2003 model. You need to tap into the green wire with the yellow tracer. The PC kit instructions are a bit out of date. If you look at the fitting instructions for the 2003 on S4 then it says green/yellow.
Also top tip.....found out the hard way.....make sure you connect the injector connections the right way as per the instructions, they will fit both ways, I got cylinder 3 wrong and have managed to illuminate the engine management light as it was missing not firing on number 3, it takes 40 start/heat up cycles to go out......or a visit to the dealer!
I have a Triumph carbon can on mine (2003 UK bike) and put the map from the web in with an aftermarket can by micron. The bike is better but there is a bit of a flat spot at 4000rpm. Everyone says a visit to the dyno is a must with the TT600, so I'm going to book mine in.
Hope this helps, let me know how you get on.
Regards,
Shaun
