Motorcycle.com
Old 04-24-2008   #1 (permalink)
Newbie
Favorite Bike: 1998 speed triple
Other Motorcycle: 748 sps
Extra Motorcycle: tl1000s
Exclamation engine management
Hi There,this Is My First Thread? So Here Goes
Just Bought A Crash Damaged 1998 Speed Triple ,mainly Plastics, I Had It Running Today After Installing A New Battery,the Engine Runs Fine,but The Engine Warning Light Is On,anybody Got Any Ideas What The Problum Could Be??? I'v Checked All The Fluids And It Looks Ok,regards Russ.
trumpet russ is offline   Reply With Quote
Old 04-24-2008   #2 (permalink)
13
Favorite Bike: BRITTEN
Other Motorcycle: 955i
Cycle up to operating temp 3 times (start bike, get to op temp, turn off = 1 cycle), it should come out of "limp home mode". Light'll go off after that.
SPEED SAVESİ
13 is offline   Reply With Quote
Old 04-24-2008   #3 (permalink)
Newbie
Smile engine management
Thanks Man ,you Just Saved Me A Fortune,regards Russ.
Old 04-24-2008   #4 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
You might want to find out why the light is on... Any OBD-II reader can get the code for you, & if you're going to tweak stuff a TuneBoy will read codes and allow you to set lots of different parameters.
Cheers,
-Kit
Old 04-25-2008   #5 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Just because light is on does not necessarily mean it is in limp-home mode. It just means that a sensor has detected a fault & has registered on the ECM which trips the MIL light. It will only be in limp-home mode if the fault is still present, Indeed in this case since it runs fine after replacing the battery, it evidently isn't in limp-home mode, therefor the fault that set the lamp initially is not currently present.
Your MIL could be associated with a number of things - a low battery voltage for example (which it clearly had since it was changed out)
Yes, if you do three complete warm-up/cool down cycles the lamp should go out - provided the original fault is no longer active.
The fault code will remain stored for 40 complete warm-up cycles however to allow you to retrieve them later if you require. The fault codes can be retrieved by your dealer.
p.s. Be sure to check out the Speed Triple Forum in the Sports & Touring Section. You'll find lots more info about your T509 as well as other Speedy models.
GSXR 1000 Front End Swap
Engine Management Light bigD Tiger Mods & Bolt-Ons 12 04-23-2006 03:51 PM
engine management light on. banni955 Modifications & Workshop Talk 2 08-28-2005 07:58 PM
S4 Engine Management seantbird Triumph SuperSports 7 04-25-2005 09:37 PM
Engine management light niteowl955i Sprint Forum 2 08-10-2004 03:01 AM
engine management system Modifications & Workshop Talk 2 03-17-2004 04:12 PM
