Triple tree issues
I posted this in the Classic Triple section which was probably the wrong area so I figured I should check here.
So my question(s) are:
Is there a way to remove the whole ignition module from the upper triple tree of a Thunderbird Sport? The little bits fastening the ignition to the upper tree don't appear to be bolts of any type, or at least fit any sockets I have.
Also, is there a trick to removing the lower steering bearing? I've tried heating it and "walking" it off with screwdrivers but neither has worked. Also, if I pooch it, how expensive are they to replace? I'm in the process of prepping to have some parts including the triple tree powder coated.
Assistance is greatly appreciated.
