» Log in
User Name Not a member yet?
Register Now!
Old 04-11-2008
cafetbird's Avatar
Cafe Racin' Moderator
Favorite Bike: 1996 Triumph Thunderbird
Other Motorcycle: 2002 Triumph Sprint ST
Extra Motorcycle: 1973 Triumph TR7RV
Radial Brake Conversion
I have a friend that races a T595 on the track, and he indicated that replacing / upgrading the brake master cylinder made all the difference in front brake performance. Problem is, the racing system costs $$$. Has anyone upgraded their front brake master cylinder on a Trirumph Sprint or other 955 bike? What radial brake MC will fit the 99-04 Sprint? I imagine most Nissin units would work, but which one will do the trick?
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
Photo Album
Old 4 Weeks Ago
cafetbird's Avatar
Hmm... I guess everyone just deals with the limitations of the stock brakes here....
Photo Album
Old 4 Weeks Ago
BigAl8295's Avatar
Favorite Bike: '99 Triumph Legend "The Green Wonderbike"
Send a message via Yahoo to BigAl8295
Your American friends are just waking up, give them some time.
If loud pipes save lives, I'm a hero!
Old 4 Weeks Ago
KitNYC's Avatar
Immoderate Moderator
Favorite Bike: '04 Sprint RS
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
I swapped my stock MC for a 5/8" unit from an '07 Kawasaki 600. I also put the 6-piston calipers from the Kawi onto my Sprint. I love it!
I highly recommend the 5/8" MC & 6-pot mod, but I have no clue what radial MC would be right for a Sprint. I would imagine that pretty much all of them fit, but you want to match the cylinder to the calipers you're using. BTW, I paid well under $100 for the whole setup on eBay, & the HH-rated pads were brand new.
Cheers, HTH,
-Kit
Old 4 Weeks Ago
cafetbird's Avatar
Cheers, HTH,
-Kit
Kit: Direct swap, or did it require an adapter plate?
Thanks,
Scot
Photo Album
Old 4 Weeks Ago
KitNYC's Avatar
So direct I can't even think where an adapter plate would have gone. I think I did have to swap a couple banjo bolts around, & I bought a bunch of fresh crush washers, but it was an incredibly straightforward job. Bleeding the brakes after the swap was the hardest part.
Cheers, HTH,
-Kit
Old 4 Weeks Ago
Replaced mine with a radial mc from a GSXR1000, '03 I think. It's awesome and no more air in the brake system. Also went with HH pads, and fabbed some new stainless lines with Earl's Performance Parts components. Very easy to do, and my brakes are now fantastic.
Old 2 Weeks Ago
13 13 is offline
Favorite Bike: BRITTEN
Other Motorcycle: 955i
When I first got my S3, it braked brilliantly. Over time, it degraded to want of a performance upgrade. You'll likely see performance increase from HH pads alone because they're more abrasive on discs than organic. Just be prepared to change discs more often as they go out of tolerance sooner (I use organic EBC's or SBS's and change frequently to get more life out of discs). Release brakes once stopped to help avoid accumulation of HOT pad material becoming embedded into discs (i.e., don't sit at stop lights with brakes engaged). Some race teams use high pressure water to remove this pad accumulation from discs (this embedded pad material is often confused with warped discs because of the uneven disc surface it creates). Removing pads, pushing caliper pistons out then spraying with brake cleaner (don't get brake cleaner on rims or paint)> cleaning disks with degreaser or brake cleaner> changing brake fluid & bleeding> replacing pads and seating properly> lubing brake cables all could make huge difference as well (just don't get chain spray on brakes). Hope this helps!
SPEED SAVESİ
Advice for disc brake conversion on '69 T100? decooney Modifications & Workshop Talk 0 07-28-2007 05:34 PM
GSXR 1000 front brake conversion BulldogHooligan Speed Triple Forum 2 04-11-2007 11:30 AM
Spiegler extended black brake line for Radial master upgrade For sale brettmess24 Speed Triple Forum 2 03-02-2007 12:38 PM
Anyone mount a Brembo Radial Brake master to 05+ S3 brettmess24 Speed Triple Forum 49 06-13-2006 07:10 PM
Brake Calipers Radial mount 108mm or 110mm? brettmess24 Speed Triple Forum 0 01-11-2006 07:35 PM
