Motorcycle.com
Old 04-09-2008   #1 (permalink)
Favorite Bike: Black speedmaster 07
StaggerLee's Avatar
fuel tap questions
ON - RES - PRIME
On and RES are self explanatory i guess but what is prime for? And why do modern bikes not have the PRIME option?
Why would a bike run smoother on prime - does it bypass a gauze fuel filter inside the fuel cock or does it bypass something in the carbs?
Thai me kangaroo down sport!
StaggerLee is offline   Reply With Quote
Old 04-09-2008   #2 (permalink)
Favorite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast ;-)
the petcock is vacuum controled , engine not running , petcock shuts off . the prime position is for when you've had the fuel system or carbs apart and there's no fuel in the float bowls .
"Why would a bike run smoother on prime" it shouldn't , the prime setting just bypasses the vacuum shut off function .
Woody1911a1 is offline   Reply With Quote
Old 04-09-2008   #3 (permalink)
StaggerLee's Avatar
thx for the reply
How does the mechanics of the vacuum shut off / open work?
is there a diaphragm that the vacuum opens? or some other mechanism? I wonder if a bit of dirt or such is affecting it opening?
The fuel tap is for a yam vx750 ( friends bike)
Old 04-09-2008   #4 (permalink)
sorry never had one apart , but there'll be a vacuum line from the engine to a diaphram . now what kind of valve it uses i'd assume a plunger of some sorts .
take a look and see if there's screws holding the diaphram cover on . if so id think just take it apart and inspect/clean and make sure it operating .
also check the vacuum line
ps empty the tank first
Old 04-19-2008   #5 (permalink)
Favorite Bike: My 07 TBA
midlifecrises's Avatar
Originally Posted by StaggerLee View Post
ON - RES - PRIME
What's this ON RES PRIME. I have an 07 TBA and have ON OFF RES????
midlifecrises
Age is no barrier.... born again biker!
07 TBA -- tacho, sissybar, footboards, windshield, AI removed, modified pipes.
midlifecrises is offline   Reply With Quote
Old 04-19-2008   #6 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
On/Off/Res is an old-school, non-vacuum petcock. ON flows fuel, off doesn't, & res is reserve. Much simpler than a vacuum unit, but don't forget to turn it off!
Cheers,
-Kit
Fuel Tap Pea_Fritter T3 Sport / Touring Forum 4 06-25-2007 06:23 AM
Fuel tap problem bensbrother Hinckley Classic Triples 7 09-27-2006 06:55 AM
fuel tap bigbird T3 Sport / Touring Forum 5 01-14-2006 11:00 AM
fuel tap why turn it off?? benthepaint Hinckley Classic Triples 29 04-29-2005 02:15 PM
Fuel tap EdC Modifications & Workshop Talk 24 03-24-2005 05:08 PM
