the petcock is vacuum controled , engine not running , petcock shuts off . the prime position is for when you've had the fuel system or carbs apart and there's no fuel in the float bowls .
"Why would a bike run smoother on prime" it shouldn't , the prime setting just bypasses the vacuum shut off function .
