Old 02-28-2005   #1 (permalink)
Rebuilding my 1st Triumph 650. Motor # DU13668, makes it a 1965. The block and cylinder have provisions for pressure oiling the exhaust tappets? The parts catalog calls out the same tappet (70-3059) and the same tappet block (70-1477) how was the pressure oiling of the tappet accomplished?
If I want to change, I need to remove the E6348 metering jet (how?)replace it with the T989 hollow dowel, replace the exhaust tappet block with 70-5861 and while I'm at it replace the intake tappet block with 70-4676.
Change the exhaust tappet to 70-8895? Does this have the smaller 3/32" long flat on the stem? It is unradiused, or should I while I'm replacing things replace it with the 70-8801 radiused tappet. Change the intake to the 70-3059R.
Which pushrod tube do I now use, the 70-3646 or the 70-6000. Thanks :???:
I have a 1965 T120R Basket case dal2whw Classic, Vintage & Veteran 4 05-01-2006 06:18 PM
Tappet Placement? HankQ Classic, Vintage & Veteran 8 03-17-2006 12:43 AM
Where to buy Cylinder barrels for 1965 650? Classic, Vintage & Veteran 7 06-10-2005 02:34 AM
Tappet oiling Classic, Vintage & Veteran 2 03-09-2005 09:08 PM
1965 triumph: vin decoding and engine problems Classic, Vintage & Veteran 1 04-24-2004 04:16 PM
