Hope this helps...
Formatting in a thread blows, but this is the best I can do:
Front Brakes >>>>> Nm / lb-in / lb-ft
Front brake caliper to fork >>>>> 35 / 309.8 / 25.8
Front brake hose to master cylinder >>>>> 25 / 221.27 / 18.44
Front brake pad retaining pin >>>>> 18 / 159.31 / xx
Front brake caliper bleed screw >>>>> 6 / 53.12 / xx
Front brake hose to caliper >>>>> 25 / 221.27 / 18.44
Front brake master cylinder to handlebar >>>>> 15 / 132.76 / xx
Front brake master cylinder reservoir to mounting >>>>> 6 /53.12 / xx
Front brake disc to wheel >>>>> 22 / 194.72 / 16.23
Wheels
Front wheel spindle / axle bolt >>>>> 95 / xx / 70
Front wheel spindle pinch bolts >>>>> 20 / 177.02 / 14.75
Rear wheel to stub axle >>>>> 146 / xxx / 107.68
-CT
2006 Speed Triple - Fusion White / Pazzo/Rizoma/K&N/LSL/Motovation/Micron CF Race Cans
2003 Speedmaster - Red & Black / 125/42 Jets/AI Removed/K&N /17T Sprocket/Custom Straight Pipes/Ceramic-Coated Headers
