Motorcycle.com
Old 03-29-2008   #1 (permalink)
Problem with intake air temp sensor?
Hi all, I'm getting a P0113 trouble code from the Tuneboy on my '02 955, it says "Intake air temp sensor open circuit, or short to battery". I replaced the air temp sensor, and am still getting it. Any ideas? Problem in the wiring loom or something? Thanks in advance!
trojan7horse is offline   Reply With Quote
Old 04-05-2008   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Sorry for late reply
Did you clear the error after replacing the sensor?
This is not meant to ridcule, but you did replace the correct sensor, yes? (the one at the top rear of the airbox)
I would suspect that you do indeed more likely have a short in the cable - check along the routing of the cable to see if it has been trapped by the tank or similar.
GSXR 1000 Front End Swap
Old 04-06-2008   #3 (permalink)
DEcosse, thanks for the reply. Haha, yep I replaced the correct sensor. The day I get something like THAT wrong will be the day I just hand the bike over and start trusting the monkeys at my local shop again Tuneboy's been acting a little strange - I tried to clear the fault code but for some reason it didn't work. And, the code ended up resetting after 3 heat cycles. So I'll see if I get it again but for now everything's kosher. Cheers!
coolant temp sensor spdfreak T3 Sport / Touring Forum 3 08-26-2007 03:47 PM
coolant temp sensor tiger-rover Tiger Chat 13 07-15-2006 02:20 PM
Air Temp Sensor Relocation drtim The Rocket Science Forum 10 11-01-2005 03:47 AM
Intake Air Temperature Sensor HardCharger757 Daytona Deliberations 2 08-01-2005 10:51 PM
Coolant temp sensor TbirdTuck Hinckley Classic Triples 2 07-04-2005 09:42 PM
