Motorcycle.com
Old 02-28-2008   #1 (permalink)
Spark Plug Washer Stuck!
Hi All
Removed all three spark plugs this morning on my '06 S3, two came out with washers the third washer is still attached to engine and won't shift. I have tried to lift it with a telescopic magnetic thing but it looks as though it is corroded on.
It is on the left of the engine and partially obscured by the frame on that side, so tool access is not as easy as the other two. From what I can see the surface looks OK.
So should I:
1. Defiantly remove it, if so how?
2. Leave it and screw new spark plug in without new washer
3. Leave it and screw new spark plug in with new washer
4. Any other ideas?
thanks all!
perfectweb is offline   Reply With Quote
Old 02-28-2008   #2 (permalink)
Can you pry it loose with a (dispensable) small screwdriver and then lift it out? Maybe stuff a piece of rag in the hole first to keep the little bits out.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 02-28-2008   #3 (permalink)
Favorite Bike: 03 Bonneville America
Gregger's Avatar
Other Motorcycle: 69 BSA 650
Try spraying a bit of penetrating oil on it to help loosen things up. Definitely place a rag over the hole. Try and hook with a small bent screwdriver or seal removal tool (looks like a dental pick).
Can't wipe this smile off my face!!!!
Gregger is offline   Reply With Quote
Old 02-28-2008   #4 (permalink)
Favorite Bike: 07 Triumph Sprint ST ABS
F4sSprintST's Avatar
Other Motorcycle: 06 Suzuki 650 DR
Plug washers are designed for crush, so I'd recommend getting that removed
Got 6 Pots?
- Tokico 6 pot calipers & Gafler HH pads
- PowerBronze Shield & Pazzo levers
- Trident Exhaust, TOR & 18T front sprocket, speedo healer, 2k bars
- Skyking Frame & MV rear axle sliders, Clear Alternatives smoke tailight, 6k HIDS
F4sSprintST is offline   Reply With Quote
Old 02-28-2008   #5 (permalink)
Thanks guys
looks like it has to go, I'll try to get a dental pick / similar down there, a screwdriver just does not seem to have any effect.
The problem is trying to get something underneath to hook it out, it's at the bottom of a 6" deep by 1" dia hole, so maneuver room is very tight. I'll let you know how I get on.
Old 02-28-2008   #6 (permalink)
PeteH's Avatar
I`d try tapping it first as mentioned, then re insert the plug and see if it picks up on the threads, or re insert the plug till hand tight, then tap and wiggle the plug.
Best of luck
PeteH is offline   Reply With Quote
Spark Plug Washer Stuck! perfectweb Speed Triple Forum 5 02-28-2008 06:43 PM
no drain plug crush washer ?? jerryb Twins Technical Talk 10 10-29-2007 10:50 PM
oil drain plug washer SamaR Sprint Forum 24 08-02-2007 09:04 AM
oil drain plug washer peter_s Twins Technical Talk 8 07-08-2007 08:02 PM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 11 04-03-2007 04:14 PM
