Motorcycle.com
Old 02-24-2008   #1 (permalink)
PeteH's Avatar
HELP Please - Tiger wont start
The intermittent problem when starting the bike is now terminal. Thumb starter and the relay clicks in, lights if on go out. Clutch switch ok and have a neutral light.
Checked the voltage across the solenoid and only get 10v the solenoid works fine off the bike powered by the battery only.
So, where`s the 2v gone.
Thanx in advance
Pete
PeteH is offline   Reply With Quote
Old 02-24-2008   #2 (permalink)
Is it time for a new battery?
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 02-24-2008   #3 (permalink)
Favorite Bike: 2000 Sprint RS
Other Motorcycle: 82 BMW R65LS
loose terminals and/or corroded cable?
JohnB is offline   Reply With Quote
Old 02-25-2008   #4 (permalink)
Favorite Bike: Blue Sprint ST 1050
Pickle Jim's Avatar
Other Motorcycle: GSXR 750 K4 (Deceased)
Sounds like a cracked solder joint or sulfation in the cells of the battery (Has it gone completely flat at all).
You'll get 12V with a meter but as soon as you try to draw any serious current, internal resistance robs you of the other 2V
Pickle Jim is offline   Reply With Quote
Old 02-25-2008   #5 (permalink)
PeteH's Avatar
The battery`s a new one, charged is 13.2v and with messing around gets down to about 12.6v.
Checked the voltage at the start button and thats 11v.
Cheers
Old 02-25-2008   #6 (permalink)
Sounds like it could be a dry joint,or perhaps a short,Check the Earth cable at both ends,as this is a common problem ie Not a good enough earth,Try putting another cable from the earth to an engine mounting. Good luck. P.S If the bike is alarmed it may have gone faulty.
carr955 is offline   Reply With Quote
Old 02-26-2008   #7 (permalink)
PeteH's Avatar
Earth cable checks out ok, and the bikes not alarmed. Going round in circles at the mo, but hey ho im sure it will come good.
Edit - May have found the problem, bad joint on a lead on the outgoing cluch switch connector.
Edit again - Now sorted
bike wont start eternity Twins Technical Talk 8 12-20-2007 03:05 PM
67 T120 TT wont start. need help listo Classic, Vintage & Veteran 2 09-16-2007 10:43 AM
tiger wont start piston-broke Tiger Chat 0 07-11-2007 04:45 AM
Wont Start!! Classic, Vintage & Veteran 32 05-08-2005 11:18 AM
New bike wont start... Triumph SuperSports 10 06-08-2004 10:27 AM
