» Log in
User Name Not a member yet?
Register Now!
  #11 (permalink)
Old 03-04-2008
ckassen's Avatar
Favorite Bike: 2000RS/02 Daytona motor
Other Motorcycle: 00 RM250
Your exactly right....
  #12 (permalink)
Old 03-09-2008
DEcosse's Avatar
Keep an eye on this thread - similar intentions. You guys might even want to exchange some notes directly.
GSXR 1000 Front End Swap
  #13 (permalink)
Old 03-11-2008
wow someone beat me to it i am actually starting to do all the research to do this my self
yes the 1050 is a stroked 955 same bore different stroke also has anyone bored the motor over yet my plan is to get a set of daytona cams and 1050 crank ($1395) and rods ($172 each) and get a custom set of .030 pistons and rings ($330) i am shooting for 200 whp i am currently at 140 (race gas, open pipe , bigger throttle bodies, ported head, k/n filter and custom ecu) need to get her dyno'ed again and post it.
so has anyone elso started to do this swap and has anyone bored the sleeves of a speed or is there a company that makes bigger sleeves?
  #14 (permalink)
Old 03-13-2008
Favorite Bike: 2003 Triumph Sprint ST
Other Motorcycle: 1974 Norton Commando
I would think twice about paying that much for a new 1050 crank and rods individually when complete 1050 engines with only a few thousand miles on them seem to be readily available used in the $1,000 to $1,400 range. That would get you both the crank and the rods, plus the 1050 engine has an anti-backlash gear in the transmission that is supposed to make it shift smother and more quietly. You probably have already considered this, but the alloy liners from the Daytona are advantageous because of the friction-reducing coating applied to them, however they can't be overbored. Several racing suppliers make custom alloy liners though, including Perfect Bore in England (which supplies many F-1 teams). I believe their liners may be available through their U.S. coatings subsidiary Max Power in Wisconsin.
Coatings are another performance area you wouldn't want to overlook especially if you are trying to get that much power. Possibilities include anti-friction coating the piston skirts and bearings; thermal barrier coating the piston crowns, combustion chambers, valve faces, and exhaust pipes; and anti-wetting (e.g. oil-shedding) coating the piston undersides, crankshaft counterweights, and the intake tract.
I'll be interested in comparing notes with you as we proceed.
  #15 (permalink)
Old 03-13-2008
ckassen's Avatar
check out US chrome. I guarantee that they can bore the cylinder to whatever you want and put a nickasil liner in it...
  #16 (permalink)
Old 2 Weeks Ago
Sorry I haven't been keeping up with this thread, but I have been having to work non-stop since my last post. I've hardly had a chance to ride either; I think it has been one wash and about 150 miles in almost 2 months.
Anyway, increasing the bore isn't quite so easy because Triumph uses an open block configuration; meaning the upper half (approximately) of the liners are not supported. The liner has to be thick enough to withstand combustion pressure and piston thrust without excessive deformation wile only being supported at the top and bottom. And the liner geometry is more complex than one that is intended to fit a conventional block. There is a flange in the middle of the liner that registers it against the upper case and provides the water-tight seal (along with some sealer) as well as a flange at the top that registers against the head.
To increase the cylinder bore, you first need to overbore the upper case to accept a larger liner (assuming there is sufficient case material to allow that). Then you need to enlarge the flange clearance in the head in a similar manner, again assuming there is enough material in the head to allow that. Then you need to have new liners made that are sufficiently thick to provide the proper support for the larger pistons and fit the new, larger openings.
To minimize the amount of additional space you need, you want to use the strongest possible material that has thermal expansion properties matching those of the piston, otherwise you need to run excessive clearance. That means either using high silicon content aluminum alloy (Alusil, Nikasil, etc.) liners like are used in the Daytona engines or MMC (metal-matrix composite) if you really want maximum strength, minimum thickness and to spend lots of money.
As for sources, U.S. Chrome is as good as it get for the actual coating as far as I'm concerned, but I'm not aware that they actually custom machine sleeves for anything but conventional blocks. In fact, I don't know of any firm here in the U.S., with a track record, that is, (no pun intended) that does. I certainly don't know nearly all the firms in the business, so I'm open to suggestions. As far as I know, Perfect Bore in England is the most likely source of custom sleeves of that type.
I have a spare upper case that I purchased on eBay for the purpose of determining if there was sufficient material in the case to make this practical. I need to either have it sonic tested to determiine just how much material there is to play with. Then I need to find someone to loan me a head to do the same thing. Unless there happens to be nayone on the board with connections to the factory. That would be the easy way to get the job done.
  #17 (permalink)
Old 2 Weeks Ago
ckassen's Avatar
Check out LA Sleeve, I hear that they are the best....
  #18 (permalink)
Old 2 Weeks Ago
Hey, thanks for the tip! They are right in my neck of the woods and I have never heard of them, which probably proves I don't get out much.
TR6R Engine - T100D Engine Northern650Twin Classic, Vintage & Veteran 7 01-17-2007 10:40 PM
S3 engine vs sprint engine S32k1 Speed Triple Forum 4 11-19-2006 07:15 PM
Question about Engine oil / Engine Covers on a Bonnie..... Brk4moose Triumph Twins HangOut 6 05-31-2006 08:48 PM
Age of engine from engine number nav18tor T3 Sport / Touring Forum 4 05-26-2006 12:49 PM
Engine mods S3 Lenz Speed Triple Forum 23 11-03-2005 07:59 PM
