AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
Old 01-19-2008   #1 (permalink)
Favorite Bike: 06 Bonneville Black
NewOldSkool's Avatar
Over Gapped Plugs?
So I went to go check the gap on my new plugs and the crappy chrome plated .99c gap tool got stuck and I ended up over gapping the plug. Could I just pull the center piece out alittle with some plyers and be fine? Or is the plug toast?
Iraq is stupid!!!
NewOldSkool is offline   Reply With Quote
Old 01-19-2008   #2 (permalink)
NEW OLD SKOOL
Do not do anything to the center electrode, you will destroy the spark plug. You can bend the ground electrode (that comes up from the tread on the plug) to adjust the gap.
Norse
norse is offline   Reply With Quote
Old 01-19-2008   #3 (permalink)
pineygroveshop's Avatar
Tap the curved electrode with something and regap. Voila!
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Old 01-20-2008   #4 (permalink)
Favorite Bike: 2000 Sprint RS
Other Motorcycle: 82 BMW R65LS
In the past I'd just tap it gently on a hard surface until it came back into spec. On my bike though, I'd probably just get another new one.
JohnB is offline   Reply With Quote
Old 01-20-2008   #5 (permalink)
Thanks guys that makes sense. I knew there was a reason I didnt want to just grab the pliers first.
Iraq is stupid!!!
Old 01-29-2008   #6 (permalink)
Favorite Bike: '68 BSA Lightning 650
WaltZ's Avatar
Other Motorcycle: '78 Honda CB400a
Extra Motorcycle: '69 Triumph T120R
Ouy..................................
You shouldn't be allowed to own plyers.
WaltZ is offline   Reply With Quote
Old 01-30-2008   #7 (permalink)
Favorite Bike: Anything, but a Honda
Readmarx's Avatar
Other Motorcycle: aprilia
Extra Motorcycle: suzuki
new plugs should only be £3 or $30 (with the conversion rate...). Personally I'd buy new if you're unsure. When you do get, say, DPR8EA-9 which I think is standard for an early speed triple the first number is the heat range of the plug and the last number is the gap - the above plug has 0.9mm clearance. Hope that helps.
Readmarx is offline   Reply With Quote
irridium side gapped plugs speedblastr Twins Technical Talk 5 05-22-2007 05:47 PM
side-gapped plugs today ozbon Twins Talk 29 06-15-2006 08:40 PM
Side gapped plugs - Thanks Daz Normandy Twins Talk 10 06-15-2006 02:59 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 10:54 AM
plugs musicman59 Classic, Vintage & Veteran 8 09-19-2005 11:02 AM
