AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 01-06-2008   #1 (permalink)
Favorite Bike: Triumph Thruxton
K&N Filter Maintenance
I'm still a new rider and was showing my friend my bike. I had told him that when I bought the bike it had some mods done, D&D pipes, air box removed & replaced with K&N filters. He asked me if I was doing routine maintenance on the filters. I had no idea what he was talking about. Is this something that I need to do on my own in-between regularly scheduled maintenance?
Thanks
cowbell is offline   Reply With Quote
Old 01-06-2008   #2 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
I clean and re oil about every 12 months.it really depends on your conditions. extreme dust= more cleans.
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 01-07-2008   #3 (permalink)
Favorite Bike: 05 Thruxton
Tabletop's Avatar
K&N makes a filter cleaning and recharge kit. It has a cleaning solvent and spray oil.
Filters should be cleaned periodically, as cafecruzin said depending on conditions. I clean mine when they start to lose their pink-ish color.
How I like them to look:
In my opinion, these are an example of filters way too dirty:
Tabletop is offline   Reply With Quote
Old 01-08-2008   #4 (permalink)
pineygroveshop's Avatar
You can purchase the cleaning/oiling kit at most auto parts stores.
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Old 01-14-2008   #5 (permalink)
Favorite Bike: '99 TBird
NoDice's Avatar
A little off topic... but is the K&N recharge kit ok to use on UNI (foam) filters?
-Chris
NoDice is offline   Reply With Quote
Old 01-14-2008   #6 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
Don't use the K&N kit on the Uni (or any other foam) filters. K&N filters are cotton & use different solvents.
Cheers,
-Kit
Old 01-14-2008   #7 (permalink)
NoDice's Avatar
Kit: can you (or anyone) recommend a product to use?
-Chris
Old 01-14-2008   #8 (permalink)
KitNYC's Avatar
I have some PJ-1 filter cleaner & oil. I think I might have gotten it from Dennis Kirk, but I don't really remember as it's been kicking around for a couple years. It came as a twin-pack of aerosol cans, 1 cleaner & 1 oil.
Cheers, HTH,
-Kit
Old 01-14-2008   #9 (permalink)
Those are just starting to work....
Once a year at the most is enough to clean a K & N....They work better as they get dirty, and DO NOT require cleaning until the wire mesh is no longer visible on the filter.
I sold K & N for many years in the UK before moving to the USA.
You may wanna check out the FAQ section on the K & N site.
But, here's the relevant section direct from their site...
4. How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
Hope this clears it up a little.
AceT100 is offline   Reply With Quote
Old 01-15-2008   #10 (permalink)
NoDice's Avatar
Cheers, HTH,
-Kit
Thanks, Kit... I found several online retailers...
-Chris
K&N filter cleanliness test 4N099 Sprint Forum 13 01-17-2008 10:22 PM
K & N Air Filter John21 T3 Sport / Touring Forum 9 11-28-2007 10:34 AM
Which K&N Oil Filter? tbrown Club Cafe 3 10-24-2007 12:51 AM
Who has instaled a K&N filter in their '05-up Sprint? triumphite Sprint Forum 24 09-03-2007 06:56 AM
Is this a K&N or Uni filter Skyblue62 Twins Technical Talk 8 09-01-2007 05:52 PM
