Old 01-05-2008   #1 (permalink)
Newbie
Doctired's Avatar
Fitting Bungs & Engine mounting bolt torques
I'm new to this group and to modern machines so please forgive what may be a simple stupidly obvious question..........
I want to fit a couple of PowerBronze Crash Bungs to my 01 Sprint ST. The Instructions say they should be tightened to the Manufacturers Torque Settings. I have not bought a Manual yet and don't know if such information would be in a Haynes Type manual. Is it worth getting one? How critical are the torque settings? Any help welcomed!!
Doctired is offline   Reply With Quote
Old 01-06-2008   #2 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
My Haynes manual says 95 Newton Meters for the engine mounting bolts. I don't necessarily pay a lot of attention to torque values for, say, switchgear mounting screws or clutch cover bolts, but engine mounting bolts I usually get kinda picky about.
Cheers,
-Kit
Old 01-07-2008   #3 (permalink)
If you could advise exactly where the bungs are to be installed, I can look up recomended torque values for you.
Jhumphrey is offline   Reply With Quote
Old 01-13-2008   #4 (permalink)
Newbie
Doctired's Avatar
Thank you for replying
The bolts mount in place of the upper front engine mounts which lie between the front cam and the exhaust pipe exit. They are visible through the large oval piercings in the fairing (so the fairng does not need to be cut --theoretically!).
Silders / bungs and engine mounts pwald Sprint Forum 2 12-05-2007 12:15 AM
caliper mounting bolt gazpacho Sprint Forum 3 06-20-2007 10:55 AM
TOR mounting bolt size? Programr Twins Technical Talk 4 02-26-2007 05:33 PM
05 shock mounting bolt size GBG Twins Talk 0 04-16-2006 02:03 PM
Thunderbird Sport - Exhaust Silencer mounting bolt SportTBird Hinckley Classic Triples 6 06-21-2005 11:54 PM
