Old 10-27-2003   #1 (permalink)
TRIUMF3's Avatar
Hi,
When I turn my 99 ST off the left headlight stays on, and I have to disconnect the battery, anyone else have the same problem ? or know what the problem is :???:
TRIUMF3 is offline   Reply With Quote
Old 10-27-2003   #2 (permalink)
TRIUMF3's Avatar
Hi,
Old 10-27-2003   #3 (permalink)
TRIUMF3's Avatar
Hi,
Old 10-27-2003   #4 (permalink)
TRIUMF3's Avatar
Hi,
Old 10-27-2003   #5 (permalink)
JesusHoffa's Avatar
I hate to ask stupid questions, But which direction do you turn the Key. On my Bonnie If you turn the key Forward it turns off the motor and if you turn it off to the rear, it is an accessorry type position which leaves the light on and allows you to remove the Key. If it is not that simple the problem may be in the Ignition Switch? just a thought
[ This message was edited by: JesusHoffa on 2003-10-27 21:26 ]
Jesus Hoffa
"It is better to be hated for what you are, than to be loved for something you are not"
JesusHoffa is offline   Reply With Quote
Old 10-27-2003   #6 (permalink)
JesusHoffa's Avatar
Jesus Hoffa
Old 10-27-2003   #7 (permalink)
JesusHoffa's Avatar
Jesus Hoffa
Old 10-27-2003   #8 (permalink)
JesusHoffa's Avatar
Jesus Hoffa
Old 10-28-2003   #9 (permalink)
Sounds like it could be a faulty relay - stuck in the on position.
JesusHoffa - on the Sprint the key only turns one way. If you turn it all the way left the "third eye" light stays on, not the left headlight.
Old 10-28-2003   #10 (permalink)
headlight problem...can u help? RedDemonST Sprint Forum 1 06-13-2007 10:15 AM
'01 headlight problem austiger Tiger Workshop 18 03-24-2007 11:02 PM
Headlight Problem pigpen955 Tiger Workshop 18 11-17-2005 07:15 AM
Headlight Problem triumph_955_st Sprint Forum 11 10-26-2005 12:57 AM
Headlight Problem tridrill Triumph SuperSports 2 04-17-2005 11:03 AM
