BikeBanditMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 10-28-2003   #11 (permalink)
Sounds like it could be a faulty relay - stuck in the on position.
JesusHoffa - on the Sprint the key only turns one way. If you turn it all the way left the "third eye" light stays on, not the left headlight.
Old 10-28-2003   #12 (permalink)
Old 10-28-2003   #13 (permalink)
TRIUMF3's Avatar
Thank you Jesus Hoffa & Snowdog99 for your input,
Just to confirm, this happens when I turn the ignition off and remove the key.
This is an intermittent problem, the headlight does “sometimes” go out when I turn the ignition off. I also decided it might not be a good idea to keep disconnecting the battery every time I turn the ignition off, so now I just unplug the left headlight every time it stays on. Big pain in the ….
TRIUMF3 is offline   Reply With Quote
Old 10-28-2003   #14 (permalink)
TRIUMF3's Avatar
Old 10-28-2003   #15 (permalink)
TRIUMF3's Avatar
Old 10-28-2003   #16 (permalink)
TRIUMF3's Avatar
Old 10-29-2003   #17 (permalink)
JesusHoffa's Avatar
Hmmm I was hoping it was my Ultra Symple solution, Are their any similarities in the times it happens (IE Damp after a long Ride) I am kind of leaning with snow dog on the Relay
Jesus Hoffa
"It is better to be hated for what you are, than to be loved for something you are not"
JesusHoffa is offline   Reply With Quote
Old 10-29-2003   #18 (permalink)
JesusHoffa's Avatar
Jesus Hoffa
Old 10-29-2003   #19 (permalink)
JesusHoffa's Avatar
Jesus Hoffa
Old 10-29-2003   #20 (permalink)
TRIUMF3's Avatar
Hmmm Nope totally random, it stays on more than it goes off, does it have separate relays for each headlight :???: if so that might be the problem
headlight problem...can u help? RedDemonST Sprint Forum 1 06-13-2007 10:15 AM
'01 headlight problem austiger Tiger Workshop 18 03-24-2007 11:02 PM
Headlight Problem pigpen955 Tiger Workshop 18 11-17-2005 07:15 AM
Headlight Problem triumph_955_st Sprint Forum 11 10-26-2005 12:57 AM
Headlight Problem tridrill Triumph SuperSports 2 04-17-2005 11:03 AM
