Thanks for the reply. The Triumph doctor mentioned the location of the air relief, sure hope I don't need to go there. Yes, the breather is connected to one of the oil tank lines with an h shaped fitting. Since the motor only has about 2,000 miles on it someone else suggested that perhaps the rings have not completely seated yet and are allowing a bit more blowby than they should. Guess time will tell.
