Motorcycle.com
Old 01-05-2005   #1 (permalink)
I've got a problem with blowing the 10A fuse that controls the turn signals and back brake light. I've been through 3 fuses in 3 days. Seems to be blowing when I start her up.
I recently found out that my ignition unit (the one under the seat on the 03 bonneville) was full of water. This killed my bike, but after drying out it fired back up. I've had this fuse problem ever since.
I admit I don't know jack about wiring or what may be causing this.
Anyone have any ideas on why this may be happing? I'm baffled. I'd hate to take it in for service for something I should be able to fix myself.
Any help greatly appreciated
Sticky Side Down
London is offline   Reply With Quote
Old 01-05-2005   #2 (permalink)
Sticky Side Down
Old 01-06-2005   #3 (permalink)
That's a tough one. The only advise I can give is check the ground by removing the neg. battery terminal, clean the connection with sandpaper and put it back together with a dab of dielectric grease.
j98sprint
j98sprint is offline   Reply With Quote
Old 01-06-2005   #4 (permalink)
j98sprint
Old 01-06-2005   #5 (permalink)
Thanks j98sprint, I'll try that out. Yeah, it just doesn't make sense. Something is off.
Sticky Side Down
Old 01-06-2005   #6 (permalink)
Sticky Side Down
Old 01-06-2005   #7 (permalink)
KuzzinKenny's Avatar
Hi !! London
If it only started blowing fuses after you dryed out the ignition unit i would start by checking any wires around that area that touch anything metalic, they may have rubbed through the insulation and be causing a short and blowing the fuse. DONT ever fit a bigger fuse as that will just fry the wiring, OK !! if you find any bare wires, tape them up with insulating tape, individually.
hope this helps
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline   Reply With Quote
Old 01-06-2005   #8 (permalink)
Hi !! London
hope this helps
KK
Old 01-06-2005   #9 (permalink)
Well there are a couple of ways to approach this.
1.) Put a 10 amp circuit breaker in line and start tracing for your short to ground, because that is what you have. Inductive amp meter would be the easiest way.
2.) Put a roofing nail in place of the fuse and look for the smoke. This approach is more commonly used in those areas that lack running water and electric lights. They also straighten frames by chaining one end to an oak tree and the other to a John Deere.
JR
Olives are God's perfect fruit.
With that I'm going to have another Martini
Guttermonkey is offline   Reply With Quote
Old 01-06-2005   #10 (permalink)
JR
Powerlet blowing fuse on insert/removal? NorrinRadd Sprint Forum 5 10-17-2007 10:56 AM
Legend headlight fuse keeps blowing RideVT Hinckley Classic Triples 5 06-12-2007 06:02 PM
main fuse blowing (06 Sprint ST ABS) Lumpy Modifications & Workshop Talk 7 04-30-2007 11:18 AM
2006 headlamp fuse keeps blowing psionmark Tiger Chat 12 08-30-2006 03:54 PM
Probs with changing accy fuse from 10A to 15A? kpp80202 Sprint Forum 4 07-06-2006 04:33 PM
