Last year I bought a little solar panel charger on ebay, for about £10 or US$20. It worked out really well over the winter. The charge rate is miniscule but it was enough to keep the battery topped up, it even came with a quick disconnect fitting. It helps if you have a suitable roof to position it on, they are not much use indoors, even by a window.
