Hi,
Looking at the 98 & 99 Triumph range sheets I have, the Legend was available in Imperial Green. Both show this as a single colour (and your Avatar shows the tank with two colours), so please double-check this.
If the colour is Imperial Green, then the Triumph site shows:
Paint Manufacturer - SCHOCH; Code - 673 CAL 28; Touch-up Stick - T3120300-HE.
Your coloured parts should also have the HE suffix (as the Touch-up Paint) against their part numbers. There maybe a sticker under the tank, if you are lucky.
Hope this helps, but do double-check.
Ciao,
Geoff
