» Log in
User Name Not a member yet?
Register Now!
  #41 (permalink)
Old 03-29-2008
Send a message via Yahoo to BlueFalcon
Make it a sticky please
Hi Zam.
Thanks for the great mod. I haven't done it yet but I've been having problems wih my electrics lately and even got myself stranded after riding with the heated gear on a cold morning and after the bike sat for about a month without charging. I thought I just drained what was left of the battery and charge it. I connected a volt meter and noticed the drain, or short-comings of the charging system. I thought there was something wrong with the regulator but after reading what DickeC wrote on T595, I think I have found the source of the problem. DickeC had a link to this thread, which pointed out the issues.
The battery drain was more apparent after adding more to the bike, Gerbing heated liners, Firstgear heated gloves, then add on a Lowrance GPS and I had myself a dead battery. I am a mechanical engineer so electricity IS magic as someone already stated. I added the amount of draw, in watts, from each accessory and it seemed that the 40A alternator should suffice; I don't know what the Sprint takes for running so I have no idea what is left for my add-ons. Does anyone have this info? Maybe Triumph should publish this info so we don't get stranded by drawing more than the alternator can handle.
I digress, this is an excellent post and if I found it earlier I could have saved myself a ton of time and worry. I will complete this mod over the weekend and will report my findings.
Thanks Zam and also Dicke C (for posting the link on T595).
Awesome Thread.
Peace
05 Silver ST 1050
  #42 (permalink)
Old 04-03-2008
DrTriumph's Avatar
Favorite Bike: 2005 Sprint ST 1050 Blue
This is a great idea. I am a chiropractor, I am not the best at picturing these things in my head. I am mechanically "competent", not great not bad. I was wondering if you could post a few pictures of the wire splicing and the connections along the way. This would help the visual oriented, I am more kinesthetic learn by doing, but pictures would help immensely here, I have a 2005 ST and found one day with my grips and jacket turned on riding in the cold that my battery is a bit sluggish on the next start.
Thanks in advance if you can post some pictures.
Dr Triumph
My Photo's...
  #43 (permalink)
Old 04-03-2008
Favorite Bike: 04 Daytona 955i/02 Bonnie
Other Motorcycle: 04 Daytona 955i/02 Bonnie
http://www.vfrdiscussion.com/forum/i...howtopic=29975
If you go to that link there is some additional details and info w/ pics
  #44 (permalink)
Old 6 Days Ago
Newbie
Weak charging system
I am about to do the charge mod to my 01 tiger and was wondering. Once you have done the buton hook connections, and taped all the connections up, do you still have to re-connect the plugs from the rectifier back to the harness?
Could someone tell me where the battery ground to the frame and engine is located.
There have been other posts detailing a similar mod that entail spade connectors and cutting off th whole connector all together. Not sure I want to go this way.
The mod posted by zam70 sure looks to be the best way.
gc
  #45 (permalink)
Old 6 Days Ago
Newbie
charging mod
zam70,
Am I to understand that you do keep the plugs connected after the button hook connection and the main fuse in the fuse box still plugged in?
GC
  #46 (permalink)
Old 6 Days Ago
AVM AVM is offline
Originally Posted by gbcphoto View Post
zam70,
GC
That's how I did it on my 03 Tiger and it works great.
  #47 (permalink)
Old 5 Days Ago
DEcosse's Avatar
....Am I to understand that you do keep the plugs connected after the button hook connection and the main fuse in the fuse box still plugged in?
Sure it will 'work' but you have the ability to pass 60A in that situation - may as well not have it fused at all!
If you follow zam70's instruction in original post verbatum, then the 'button hook' connection is on the bike main harness side of the connector plugs, therefor the connector plug must be plugged in or you will have no connection from the regulator.
You should install a fuse in the bypass line to the battery & remove the primary fuse in the fuse panel.
See this post for explanation on why you should remove the fuse.
http://www.triumphrat.net/daytona-de...ml#post1010284
GSXR 1000 Front End Swap
  #48 (permalink)
Old 5 Days Ago
DEcosse is dead on.
I left the plug so an RR swap would be plug and go.
The safest (and smart way) is how DEcosse depicted.
  #49 (permalink)
Old 5 Days Ago
DEcosse's Avatar
Originally Posted by zam70 View Post
...I left the plug so an RR swap would be plug and go.....
I agree with that from that perpspective - as you indicate zam, the smaller gauge wires are in main harness anyway.
If mine ever fails again (I believe I've reduced that possibilty greatly by adding the better heatsink - the heat is what kills these things) then I would have to re-wire the replacement again as opposed to plug n play at that point. That wouldn't be an issue for me personally but your advice is well suited to those who don't want to face this rework again after initial mod.
It's all good either way - The main thing is that if the mod is done on the main harness to pull the fuse to keep the protection as designed.
Kudos to Hokie incidentally - as I re-read through this thread this morning, even though acknowledging himself as an electronics novice, recognized the potential issue with leaving both fuses in circuit.
Originally Posted by Hokie
....you are by-passing going through the fuse block, correct? If that is the case, did you unplug the 30amp fuse in the fuse block? If you don't do that, wouldn't you be running two 30amp fuses on essentially the same circuit? ....
But again zam, thanks for bringing this simple mod to everyone's attention - regardless of exactly which point it's connected (before or after the connector) it is a great mod & will operate just as efficiently either way, so that part comes down to personal choice.
Weak charging system? - the solution zam70 Daytona Deliberations 30 6 Days Ago 04:25 PM
Charging system? chukus13 Speed Triple Forum 1 03-29-2008 12:33 PM
Charging system m970456 Speed Triple Forum 1 03-16-2007 09:25 PM
charging system help! Trophy 5 04-01-2005 12:18 PM
charging system Modifications & Workshop Talk 2 03-30-2005 03:40 PM
