BikeBandit
Old 09-19-2007   #1 (permalink)
Other Motorcycle: xjr 1300 sp
Extra Motorcycle: thruxton 04
neutral light.wheres it gone.
er only just today pulled in the garage for gas and on restart no netuiral light.
clicked i ngear out again still no light.
so it was clutch in side stand up and away we go.
is this common ,is there a fix.
kind regards mark.
ps I do love this forum .
renny is offline   Reply With Quote
Old 10-07-2007   #2 (permalink)
Maybe the light bulb burned out?
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 10-07-2007   #3 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Or the switch/bad connection....
Keep it simple if you can: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 10-20-2007   #4 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
You can test for whether it is just the bulb or the switch quite simply: if the switch is bad, with bike in actual neutral, then you should be unable to start the bike with the sidestand down even if clutch pulled in; if it does start then it says the switch is OK and problem is burned out indicator light.
If it does not start until you raise the sidestand, then it says the switch is bad.
GSXR 1000 Front End Swap
neutral light Zansongs Twins Technical Talk 4 10-01-2007 02:15 PM
No neutral light FlyingScot Twins Technical Talk 1 03-20-2007 11:25 AM
neutral light geebee Speed Triple Forum 2 10-16-2006 12:36 PM
Neutral light went out, then.... Riven Twins Technical Talk 10 10-03-2006 03:43 PM
No Neutral Light rdm1 Tiger Workshop 2 10-27-2005 02:20 PM
