Motorcycle.com
Old 09-06-2007   #1 (permalink)
Head size for rear brake disc on 2006 Speedmaster
I have a mate coming tomorrow to assist (well do actually) the rear disc and pads on my 06 speedy.
Whilst he will probably be bring tools, to be on the safe side I am checking my own.
Have got the half inch torque wrench, have the correct socket for caliper removal and have the bits for wheel removal.
Don't really have the correct size 'allen' type head to remove the disc from the wheel.
If anyone could advise the size I will get it today - hopefully with adapters to put on half inch torque wrench.
Anyone know?
All the best
Stan
mr_stang is offline   Reply With Quote
Old 09-06-2007   #2 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
what you need
Have on hand the following
6mm allen for the torque wrench
propane torch
hammer type impact screw driver with an adapter for the above
242 type locktite
wire brush to clean the screws
Heat the heads of the screws only need to go to about 400 F(just to hot to touch on the back side of the disk and boss on the hub. Loosen with the impact driver and turn out with the 6mm allen key while still warm. wire brush to remove the factory thread locker. Then allow to cool, doing this will allow you to re-use the factory fasteners! They cost $6.00 usd here. re-assemble using clean screws and 242 locktite work fast to get torqued before the locktite starts to cure! Check torque but it should be about 22-24nm.
To convert Nm to Ftlb multiply by.7376
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 09-06-2007   #3 (permalink)
6mm - thanks.
ANd for the rest of the info thanks as well!
Stan
Old 09-08-2007   #4 (permalink)
Thanks for pointers/advice and everything.
Now have nice sintered pads and nice new disc.
The old pads were down to the metal - after 10,000 km (The guy before me must never have used the front brake!0.
Hopefully will not have to touch them for another 25k!
Stan
Chain and rear brake disc Calzor_Suzay Sprint Forum 2 04-13-2007 06:27 PM
Cracks in Speedmaster Brake Disc Flynn Modifications & Workshop Talk 1 03-10-2007 07:40 PM
Rear Brake Disc discolored? 5bassman Modifications & Workshop Talk 7 09-30-2006 11:16 PM
Rear brake disc replacement... Triple_Scott Speed Triple Forum 0 04-05-2006 04:45 PM
Rear disc brake - 77 Bonnie OzBloke Classic, Vintage & Veteran 4 01-25-2006 07:55 PM
