Old 08-28-2007   #1 (permalink)
Favorite Bike: 2007 British racing green and cream America
Kem770's Avatar
backfires
My TBA sometimes backfires when it starts. It sounds cool, but should I be concerned? When a bike backfires does this mean its running rich, does it mean its running lean, or does it just mean it’s a cool freaking bike?
Kem
"It's in my skin, bitch." Dudley, "Wild Hogs"
Kem770 is offline   Reply With Quote
Old 08-28-2007   #2 (permalink)
Favorite Bike: any Triumph. also love Nortons
hans's Avatar
Other Motorcycle: one is enough but I'd love a thruxton just to use for cafe racing.
Extra Motorcycle: nah
now only the rider backfires
My T100 backfired quite a deal whilst it still had the air injection fitted. Having removed it, the backfiring has been reduced to almost zero. it also seems to run so much smoother.
NO-ONE IS COMPLETELY WORTHLESS
THEY CAN ALWAYS SERVE AS A BAD EXAMPLE
vado vestri own via
hans is offline   Reply With Quote
Old 08-28-2007   #3 (permalink)
Kem770's Avatar
The AI is removed. It doesn't backfire every time it starts just sometimes. I do think its cool, but I just want to make sure it isn't a symptom of something else.
Kem
Old 08-29-2007   #4 (permalink)
Favorite Bike: 04 thrux blk
Gohm's Avatar
Other Motorcycle: 06 klr 650 grn
It isn't normal for that to be happening. It means it's a cool freaking bike in need of a tune up. Could be your mix screw setting, starting procedure or plugs. Valve timing issues, air leaks & out of balance carbs can also cause backfiring. Backfiring usually denotes a lean issue.
Be a "weekend warrior" 7 days a week, 365 days a year!
My Photo Album
"A wink is as good as a nod to a blind bat" - MP
Gohm is offline   Reply With Quote
Old 08-29-2007   #5 (permalink)
Favorite Bike: My '03 America
agogel's Avatar
Backfires
Hey Kem,
Usually when it backfires at startup it is because you are applying throttle when none is required.
Pull the choke out about half-way and stay off the throttle.
See if that helps. If not, something else is going on.
Backfires can blow holes in your airbox so keep an eye on it.
Tony G
"If you don't get what you really want, it's your own fault"
agogel is offline   Reply With Quote
Old 08-29-2007   #6 (permalink)
Medic09's Avatar
It's only cool when you get flames coming out the pipes...
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'01 Sprint ST
'78 Honda CB750K
Medic09 is offline   Reply With Quote
Old 09-03-2007   #7 (permalink)
yep, same thing Agogel said. I found I was applying throttle when I didn't know it. bang, blow up the airbox.
mike
It's a good day for ridin.
mjtool is offline   Reply With Quote
Trophy Backfires Trophy250 Modifications & Workshop Talk 1 03-27-2006 09:12 PM
Trophy Backfires Trophy250 Twins Talk 0 03-27-2006 07:04 PM
BackFires and Pings DaffyDuc Speed Triple Forum 5 09-15-2005 01:47 PM
Backfires tstacy Speed Triple Forum 3 05-25-2005 02:33 AM
s3 '03 w triumph hi silencer can backfires timoteusmunk Speed Triple Forum 11 12-01-2004 04:08 PM
