Backfires
Hey Kem,
Usually when it backfires at startup it is because you are applying throttle when none is required.
Pull the choke out about half-way and stay off the throttle.
See if that helps. If not, something else is going on.
Backfires can blow holes in your airbox so keep an eye on it.
Tony G
"If you don't get what you really want, it's your own fault"
