Old 08-16-2007   #1 (permalink)
Favorite Bike: The one I'm riding
97sprint's Avatar
Other Motorcycle: 1980 Suzuki GS1000S
Mixing oil
My question is ...........
is it ok to mix different brands of oil?
If I used XYZ brand--full synth with say Mobil 1 full synth.
Is this ok ?
I'm talking maybe 1/2 quart/litre not 2 qts/ltrs of each.
Just to "top off" between oil changes.
Keith
When in doubt,accelerate
97sprint is offline   Reply With Quote
Old 08-16-2007   #2 (permalink)
Favorite Bike: 1967 triumph T120R old sc
el_nino3's Avatar
Cool
its alwayto each ther u know the rest the only reason i use the same oil is....u want the best oil for the engine and there can only be one type that is the best so why not make it 100% of the best oil? now on the other hand if i was broke down , on some highway i would be thankful for any type oil available and ..........................................maybe a beer
dont let ur meatloaf
el_nino3 is offline   Reply With Quote
Old 08-16-2007   #3 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
I use whatever synthetic oil is on sale when I need oil. Because it is sold in quarts or liters, I often have a partial quart bottle left over after an oil change. It has never bothered me to use the remainder of the quart bottle with some other brand to get the right amount of oil in the bike. They have minor variences in characteristics, but as long as the oil is clean and there is the right amount, I don't worry too much.
Will
SponsorHouse profile
Old 08-16-2007   #4 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
If you're using full synth oil of the correct weight that doesn't have nasty car additives, you'll be absolutely fine. (If you're only talking about half a quart, even some of the bad car stuff would probably be okay.)
Bottom line is, don't sweat it.
Cheers,
-Kit
Old 08-16-2007   #5 (permalink)
The bottom line is you can use just about any oil of the correct viscosity and grade, mixed in any combination you like, provided that you change it & the filter frequently enough based on how you run the bike. All the rest is commentary.
B02S4 is online now   Reply With Quote
Old 08-17-2007   #6 (permalink)
97sprint's Avatar
Thanks !!
I only need to add like 1/2--1/3 quart.
I'm taking a 1000 mile loop next weekend so just curious about mixing different brands.
Keith
Old 08-17-2007   #7 (permalink)
Favorite Bike: 2002 Triumph Sprint ST
Other Motorcycle: 2002 Harley FLHR Road King
All modern motor oils will mix without a problem. That goes for synth and dino oil mixed together as well. In a pinch, any oil is better than no oil.
SaddleTramp is offline   Reply With Quote
Mixing Tires? DanPtWash Speed Triple Forum 1 07-31-2007 12:15 PM
Speedy & me mixing it up (or attention whoring - you decide) JayArr Speed Triple Forum 4 05-16-2007 08:07 PM
mixing and matching parts psds Classic, Vintage & Veteran 1 06-01-2006 03:04 PM
Mixing tire (tyre) types on a Bonneville... n578md Twins Talk 9 05-30-2006 07:43 PM
Factory paint mixing codes. Deuce Twins Talk 3 08-06-2005 02:05 PM
