Motorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 09-24-2003   #1 (permalink)
paulodse
Just thought it might help someone to know that these pipes need the pilot screw 3&3/4 turns out from their seats to avoid running lean. They flow more gas than the originals. Also, don't take your carbs off to adjust these screws unless you need to drill the anti-tamper plugs (US models) since they can be reached with a geared/flexible right-angled screwdriver available from Motion-Pro and others or, as I did, borrow one from a Kawasaki dealer (it's part of their factory-supplied tool kit - and more than likely is for other manufacturers too...) for ten minutes - which is all it should take. I've saeen somewhere someone suggesting removing carbs to adjust the screws...
I'll get my bike dyno'ed at some point and let you know optimum jetting FYI, though I'm not looking for top-end so it'll be tuning for throttle response and mid-range - hurrah!
Meanwhile, thank again to Mick for spot-on advice - keep up the good work, fella.
Cheers all & happy riding
Paul, London
Old 09-24-2003   #2 (permalink)
paulodse
Paul, London
Old 09-24-2003   #3 (permalink)
paulodse
Paul, London
Old 09-24-2003   #4 (permalink)
Daytona's Avatar
I love the sound those pipes make, especially on the over-run :wink:
Enjoy!
Daytona is offline   Reply With Quote
Old 09-24-2003   #5 (permalink)
Daytona's Avatar
Enjoy!
Old 09-24-2003   #6 (permalink)
Daytona's Avatar
Enjoy!
Old 10-22-2003   #7 (permalink)
paulodse
OK - just to aded that I've just had the cams out to do valve clearances and found some prat had put the inlet cam in a tooth out (retarded) so... the mixture screws will now have to come out a little further since she's now flowing more air... and making bags more torque! And yes, these pipes do sound lovely, if not quite as phat as the ones with the big holes in that they replaced, and what they've done to the looks of my otherwise standard (mini irridium indicators aside) Trident is quite stunning - very imposing!
Paul
Old 10-22-2003   #8 (permalink)
paulodse
Paul
Old 10-22-2003   #9 (permalink)
paulodse
Paul
Old 10-22-2003   #10 (permalink)
paulodse
Paul
replacement seat cover for early speed triple bfishman T3 Sport / Touring Forum 4 06-21-2007 12:17 AM
are later trident handlebars higher than the early trident bars trent RAT - United Kingdom 3 06-08-2006 04:18 PM
are later trident handlebars higher than the early trident bars? trent Modifications & Workshop Talk 3 06-05-2006 12:22 PM
Shock and ow!! Early Daytona 900 Windchill Daytona Deliberations 29 02-13-2006 04:46 AM
95 trident 900 D&D Pipes/carb jet ? T3 Sport / Touring Forum 21 04-02-2005 08:04 PM
